rear sway bar wont bolt back up???
Old Apr 29, 2007 | 06:46 AM
dc4teg95's Avatar
Default rear sway bar wont bolt back up???
ok so i just installed my megan rear lca and now the endlinks have a gap between them and the sway bar. has anyone had this problem? its a factory gsr sway bar btw if that makes a difference.
Old Apr 29, 2007 | 11:13 AM
98GSRDC2's Avatar
Default Re: rear sway bar wont bolt back up??? (dc4teg95)
you sure you got the right ones? i know ek ones are longer and stick out
Old Apr 29, 2007 | 02:00 PM
mrdeadman's Avatar
They let me pick
pics?
Old Apr 29, 2007 | 06:55 PM
dc4teg95's Avatar
Default Re: rear sway bar wont bolt back up??? (mrdeadman)
i dont hve any pics. the box they came said 92-95 civic/94-01 integra. i went to the website and matched the numbers while back before puttin them on the other day. the only note they had said that for use of sway bar on the DC platform must use a nut for the the stock bolt. the hole was just shy to small so i was like ill use a slightly smaller bolt but that went out the window after i realized the nice gap. so i removed the rear sway bar for now til i figure something out
Old Apr 30, 2007 | 09:21 AM
Boudreau's Avatar
i had that exact same problem on my LS... couldnt figure out how to get them together... i ended up just taking it off and driving without one at all.thumbdown:
Dan :
Old Apr 30, 2007 | 09:30 AM
SickIntegraWon's Avatar
i have the same problem, i bought my megan lcas and the sway bar was just shy of bolting up to the lca. I thought maybe you can get some sort of spacer or bushing between the sway bar and lca and get a longer bolt. But mine is not connected as of now.. Anybody have an answer??
gonmaro
Suspension & Brakes
Apr 8, 2009 05:31 PM
Mikes2000civicsi
Mar 27, 2008 09:02 PM
96 GSR-T
Suspension & Brakes
Mar 11, 2008 07:21 PM
mixmastabob
Jan 6, 2004 09:51 PM
Briman2021
12
Jul 26, 2002 07:28 AM
