ITR rear sway bar
Old Apr 28, 2007 | 07:44 PM
lubmyinteg's Avatar
Default ITR rear sway bar
i have a 99 LS with a stock rear sway bar. i just bought a rear '96 ITR sway bar. password jdm told me it would be a stright bolt on but i tried to put it on but the D-bracket was too big for the stock base bracket that bolts to the frame. any suggestions what i can do about the D-bracket connecting to the feame? thanks.
Old Apr 28, 2007 | 08:12 PM
jdmdc213's Avatar
Default Re: ITR rear sway bar (lubmyinteg)
http://i169.photobucket.com/al...9.jpg you need to buy this
Old Apr 28, 2007 | 08:28 PM
Harryflores's Avatar
Default Re: ITR rear sway bar (jdmdc213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdc213 &raquo;</TD></TR><TR><TD CLASS="quote">http://i169.photobucket.com/al...9.jpg you need to buy this</TD></TR></TABLE>
x2
a guy has them for sale in the market place!
https://honda-tech.com/zerothread?id=1940931
Old Apr 28, 2007 | 08:58 PM
jdmdc213's Avatar
http://i169.photobucket.com/al...9.jpg You need to buy that
Old Apr 28, 2007 | 09:50 PM
bshshondaman06's Avatar
you need the asr rear subframe reinforcement kit. its usually found for 180 but its alot cheaper then getting your rear subframe put back together. its fairly simple to install and worth every penny.
Old Apr 28, 2007 | 10:28 PM
numbnuts22715's Avatar
You dont need any particular one, you just need subframe reinforcement.
You can get beaks, asr, or even that cheaper one(the brand slipped my mind).
And that swar bar will make a world of difference, I installled mine probably close to 2 months ago, and I love it.
Old Apr 28, 2007 | 11:05 PM
lubmyinteg's Avatar
Default Re: (numbnuts22715)
wow thanks guys... so im kinda on a tight budget... can i get the bracket and have it fit my LS back end?... without the subframe kit, cuz i just know that is alot of $$$
Old Apr 28, 2007 | 11:08 PM
doood's Avatar
been there done that
Default Re: (lubmyinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lubmyinteg &raquo;</TD></TR><TR><TD CLASS="quote">wow thanks guys... so im kinda on a tight budget... can i get the bracket and have it fit my LS back end?... without the subframe kit, cuz i just know that is alot of $$$</TD></TR></TABLE>
you need some sort of reinforcment kit otherwise you'll tear out the subframe. it's not pretty when it happens.
Old Apr 28, 2007 | 11:21 PM
lubmyinteg's Avatar
Default Re: (doood)
can u give me a link to one u recommend... i didnt even know about thoes till now... haha. and will the subframe need after market controle arms?
Modified by lubmyinteg at 12:33 AM 4/29/2007
Old Apr 29, 2007 | 02:16 AM
I got one from beaksproducts.com, its like 60 bucks or something.. not bad insurance for a headache that would cost a LOT more than that.
Old Apr 29, 2007 | 11:22 AM
98GSRDC2's Avatar
you need bracket and some sort of reinforcement
Old Apr 29, 2007 | 11:46 AM
redGSRguy's Avatar
Default Re: (98GSRDC2)
BSQ is all you need it is $20
http://www.geocities.com/bretq/
Old Apr 29, 2007 | 11:57 AM
Default Re: (redGSRguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">BSQ is all you need it is $20
yep, thats the third brand, i always forget the name.
I believe that guy also has a how-to make your own kit, if you need it right away.
Basically you need 2 strips of metal, just to redistribute the load of the bolts onto a larger surface area.
Old Apr 29, 2007 | 12:05 PM
tomithy's Avatar
your options are, in order of increasing price:
bsq, beaks, asr, comptech
Old Apr 30, 2007 | 11:03 AM
lubmyinteg's Avatar
Default Re: (tomithy)
the comptech says it's a tie bar and a subframe reinforment kit in one. is it worth buying or should i just go wiht the asr
Old Apr 30, 2007 | 11:07 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lubmyinteg &raquo;</TD></TR><TR><TD CLASS="quote">the comptech says it's a tie bar and a subframe reinforment kit in one. is it worth buying or should i just go wiht the asr</TD></TR></TABLE>
Get the beaks. Unless you're a "baller" and have the money to buy an ASR. I have a Beaks and it works just fine. http://www.beaksproducts.com/contact.htm
Old May 26, 2007 | 05:57 AM
malubawla's Avatar
Default Re: (mrdeadman)
does the stock endlinks from an integra rear sway bar work with the itr rear sway bar?
Old May 26, 2007 | 06:34 AM
P0sTaL's Avatar
the beaks kit works wonders and its not to $$$$. As for the stock endlinks they work fine with the ITR sway bar.. just make sure to do it right the first time.. im sure alot can say take ur time and get it right the first time save you money and pain in the long run...
Modified by P0sTaL at 11:56 AM 5/26/2007
Old May 26, 2007 | 12:35 PM
Championship's Avatar
Default Re: (P0sTaL)
i bought one before and had to sell it, my Lower Control arms were blox and needed the oem ones and also, it is no f*ing bolt on, i drilled the subframe and had too much trouble with the welded nuts inside the frame and i had the beaks kit also.....i sold the swaybar and just called it a night
Old May 26, 2007 | 01:04 PM
JDM_CRX_PLEASE's Avatar
i also hav ea itr rear sway bar, and its the best
Old May 26, 2007 | 02:49 PM
Default Re: (JDM_CRX_PLEASE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">i also hav ea itr rear sway bar, and its the best</TD></TR></TABLE>
this has nothing to do with the OP's tech question
pooorman's type-r
Jun 15, 2008 07:55 PM
aemintgsr
Jan 19, 2008 05:09 PM
lubmyinteg
Suspension & Brakes
Apr 29, 2007 11:35 PM
dat_flip
Suspension & Brakes
11
Jan 28, 2005 07:38 PM
HybridIntegra
20
Nov 16, 2004 07:38 PM
