Need some help quick, integra (DA) rear brake disk conversion on EJ, questions
Hey sorry guys I havent had much time to reasearch as this problem just came up today and I can pick up this Integra rear set tomorrow if all is ok.
My questions is what is needed to make the DA integra brakes work on the EJ civic? Can I use my trailing arms from my civic on the integra brake? Also what lines and/or cables would I need?
Sorry again for the lack of research on my part. Im just trying to get this finished so I can tune the car install some other small things so I can autocross again!
TIA
TIA
This question poses alot of what ifs. If you found this car in a junkyard unbolt the entire lower trailing arm. If you are getting it from "some guy you know" hopefully you are getting the entire lower control arm. In either case you will need to unbolt your LCA's with the drums. From there it should be a direct swap. Also be sure to get a set of SI e-brake cables from the dealer. I'm really not sure if you could use the set from the Teg if it's available, but I got a set for an SI on my hatch and they work fine. After I got it all on and adjusted the e-brake cable, they were not even. I have not experienced any troubles due to that.
good luck
good luck
DOH! Sorry, I didn't catch the DA part.... I know the DC2 has like 5 star bolts on the back of them that will unbolt the hub. Sorry if I confused you, it was not my intention to mislead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kingcobra33 »</TD></TR><TR><TD CLASS="quote">DOH! Sorry, I didn't catch the DA part.... I know the DC2 has like 5 star bolts on the back of them that will unbolt the hub. Sorry if I confused you, it was not my intention to mislead. </TD></TR></TABLE>
Its ok no biggie. Just want to make sure I can put these one without having to buy 200 dollars worth of other parts.
94allmotor
18
Feb 6, 2009 01:09 PM
Josh22999
Mar 28, 2007 10:30 AM
aaronhume
49
Nov 7, 2005 01:26 PM
MugenHonda
Jun 12, 2003 05:14 PM
