which up is the correct up for cam gears?
Old Apr 28, 2007 | 02:37 PM
Tatakai's Avatar
Default which up is the correct up for cam gears?
i was adjusting my timing because it was off by a tooth, but now that i look at it im not sure. do i set the "up" arrow on the cam gears in relation to the motor (looking at the top of the head where it meets the valve cover) or in relation to the ground? here's a pic, exhaust cam is UP in relation to the motor, intake is UP in relation to the ground. number 1 piston is like 1* after TDC (the mark on the end of the crank gear and the block)
pics enclosed for you're pleasure.
Old Apr 28, 2007 | 02:40 PM
sicones's Avatar
Default Re: which up is the correct up for cam gears? (Tatakai)
your intake cam is off by a tooth, the exhaust look aite, it should be straight with the motor
Old Apr 28, 2007 | 02:42 PM
Tatakai's Avatar
Default Re: which up is the correct up for cam gears? (sicones)
the intake is off by a tooth cuz i was tryin to figure out which one was correct lol
thanks for the quick reply!
EGhatch87
Jun 22, 2008 10:25 PM
Old_Honda
Jan 10, 2006 09:19 AM
jdmcx
10
May 7, 2004 04:04 PM
B_1_8_hatch
Mar 17, 2003 05:53 PM
berkel
Aug 9, 2001 06:23 AM
