EG suspension
Old Apr 28, 2007 | 10:21 AM
Bayareajdm's Avatar
Default EG suspension
I just recently got an EG and it came with Tokiko Blue and some unknown coil-overs. What are some good suspension brands or set up out there in the market?
Old Apr 28, 2007 | 02:58 PM
orb's Avatar
orb
Default Re: EG suspension (Bayareajdm)
I had Tokico Blues on my 3rd gen Teg. Personallly, I thought they were great. Maybe you should think about keeping them and changing to a quality spring... ?
Old Apr 28, 2007 | 05:16 PM
kaiba's Avatar
Tokico blue are just oem replacement, btw. If you looking for coilover i recommand Ground-Control.
Old Apr 28, 2007 | 05:51 PM
orb's Avatar
orb
Default Re: EG suspension (kaiba)
While the blues are not a top-of-the-line performance shock, they are rated for a much firmer spring than OEM.
Anyway, to answer your question... you will just have to do your own research bud. Do some searches for Eibach, Koni, Ground Control, Tein, and Tokico. That should bring up plenty of reading material for you.
Old Apr 28, 2007 | 06:00 PM
Rainy City's Avatar
Default Re: EG suspension (orb)
I had tein s-techs on my old EG. it wasnt that low at all, but it was really smooth. better than stock i must say.
Old Apr 28, 2007 | 06:07 PM
batzcivic's Avatar
i have tokiko blue on my eg its a smooth ride i love it. keep in mind i got matching springs.
Old Apr 28, 2007 | 06:28 PM
EGJason's Avatar
Default Re: EG suspension (batzcivic)
I'm quite happy with my KYB AGX's. 4-stage pressure control gas struts
If you replace the springs (or get lowering springs), make sure you get a front and rear camber kit, otherwise nobody will be able to align it properly.
Old May 9, 2007 | 02:51 PM
orb's Avatar
orb
batzcivic is right. Matching springs to dampers is key to happiness.
Old May 21, 2007 | 02:25 PM
bayeg6's Avatar
well i have an eg myself and i have konis and ground control w/ the groundcontrol upper mopunts on all four corners. i also have custome spring rates for the car cause i went and had the car coner wieghted to find out what spring rate will be best for my car
Old May 21, 2007 | 02:48 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: EG suspension (bayeg6)
Kyb Agx shocks, H&R springs, Tein springs, koni yellow shocks, tokico illuminas.
Those are about the ony brands I'd buy in my budget range.
J_M_B
Jul 9, 2007 09:16 PM
broketuner-Sol_Si
Suspension & Brakes
Dec 17, 2005 11:43 PM
AmginE
Mar 16, 2005 12:12 PM
