im sure this is covered somewhere but why do some people heat wrap their headers
Old Apr 28, 2007 | 09:31 AM
mattsnooz's Avatar
Default im sure this is covered somewhere but why do some people heat wrap their headers
^^why do some dudes heat wrap headers?, and yes i've searched and found stuff on heat wrap but not actual people's input on why or why not to wrap headers in heat wrap. thanks in advance!
Old Apr 28, 2007 | 09:35 AM
mgags7's Avatar
Using heat wrap keeps the heat inside the heat wrap. That means out of the engine bay. Which is good.
The bad thing about it is that it makes your header corrode more due to holding in moisture and such.
Old Apr 28, 2007 | 09:52 AM
Buffalo's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Using heat wrap keeps the heat inside the heat wrap. That means out of the engine bay. Which is good.
The bad thing about it is that it makes your header corrode more due to holding in moisture and such.</TD></TR></TABLE>
x2 on that but i may add that hotter gasses travel faster so keeping the heat from escaping the header your have better exhawst gass flow = little more power
Old Apr 28, 2007 | 10:32 AM
Si Speed's Avatar
In certain cars, it may also help the A/C lines from melting but I've never heard of that happening on any Prelude. I've just got a chap Megan header so I think I may put some wra. I won't be too hurt if it goes bad. I'll just get another one.
Old Apr 28, 2007 | 10:40 AM
BlownH23a
Guest
Posts: n/a
i recorded a 150rpm faster spool up from wrapping my turbo manifold. its awesome..noob, search
Old Apr 28, 2007 | 03:11 PM
Hawkze_2.3's Avatar
Default Re: im sure this is covered somewhere but why do some people heat wrap their headers (mattsnooz)
They do it because they like rust
...........and lower underhood temps.
Old Apr 29, 2007 | 04:54 AM
mattsnooz's Avatar
Default Re: im sure this is covered somewhere but why do some people heat wrap their headers (Hawkze_2.3)
http://www.centuryperformance.com/heatwraps.asp . okay so im not wrapping the header. thanks people!. AC line is double insulated anway infront of header. i would think it would be okay unless some dum dum took it off for what ever reason. mine is there so i probably shouldn't have to worry about my ac line melting.
Old Apr 29, 2007 | 08:30 AM
lude27's Avatar
also if you have some cheapy ebay headers, header wrap will probably cause them to crack from the heat alone in a very short time.
Old Apr 29, 2007 | 04:00 PM
alphajesse's Avatar
Not only will it reduce underhood temps, the exhaust gases will stay hotter and improve velocity.
Killer4Sho
Jul 1, 2009 12:24 PM
vietdoughboy
Nov 9, 2007 02:24 PM
Rob.
23
Aug 8, 2004 07:43 AM
ludenutz
Aug 20, 2003 02:35 PM
B00ST2nR
Jan 13, 2002 05:59 PM
