1991 CRXSI CAM HEAD TURBO ZC ?????
WHAT CAM SHOULD I USE FOR MY CAR
COULD I USE SOMETHING STOCK OUT OF ANOTHER D SERIES OR SHOULD I JUST KEEP THE CAM THATS IN THE ZC HEAD
IM BUILDING A SOHC ZC MOTOR I WANT TO RUN TURBO COULD I USE D15 PISTONS WITHT THE STOCK ZC RODS AND WHAT CAM YOU GUYS THINK FOR THIS ON THE STOCK ZC HEAD AND I GOT A D15 HEAD AND AN SI HEAD WHAT YOU GUYS THINK I DONT THINK THE D15 HEAD WILL WORK ON THE ZC BLOCK WILL IT? HOW BOUT THE SI HEAD WILL THAT WORK
Si head is the same as the ZC sohc head. Depends on who you belive but the cams are the same or slightly different. A Si cam will fit in the ZC head if you want to do this.
the ZC cam is more aggressive then the d16a6 cam. it is an overal better cam for just about anything. NA or boost. if your gonna go aftermarket i woud stick with the ZEX stage 2 cam with springs and retainers. from experience i know its a good cam that has made good power on my single cam (over 350+ whp)
but as far as stock cams for SOHC's the ZC is the best.
oh and FYI your caps is stock on.
goodluck.
**** EDIT sorry guys. made good power on my Z6. but yeah the ZC cam is good
sorry sorry sorry
Modified by turbodcivic510 at 10:24 AM 4/28/2007
goodluck.
sorry sorry sorry
So you guys think thats the sohc zc is a g0od turbo motor? and the d15b2 piston are g0od to put in the zc block witht the zc rods cause there thicker and stronger correct? and what ecu can i use the Si ecu? 0o0o and anothrer thing the zc motor was out of an automatic but i can put fly wheel and **** and put the si trans on it ?? and will the si distributor work on the zc head then i can use si ecu and i got a ls head the d16a1 and trans can i use any of the gears out of the d16a1 trans for the SI trans i got 91 crx si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95f22a1 »</TD></TR><TR><TD CLASS="quote">i was just about to ask the same question!
What was the question?? Between the lack of punctuation bad spelling and rambling I dont know the question?
charlieboyhonda
Jul 22, 2009 05:36 PM
