PROBELM WITH SPEEDOMETER. :/
well, i was driving my ej1 about 15 minutes ago and i was going about...70mph on the highway and my speedo jumped up to 100mph. Then when i exited the highway it went all the way to the needle and this is how it ended up....
ok bro i found the pic
Look at your tranny and then take off the main bolt that is attached to you tranny to the sensor.
Then just pull it out should come out easy.
But sometimes the clip that goes to the tranny sensor could be bad too so just plug it off and plug it back on first see if it does anything before you bolt anything off bro
Did the needle go all the way around? If so, remove the cluster and the cluster bezel, then move the needle counterclockwise until it sits back on the stop pin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Did the needle go all the way around? If so, remove the cluster and the cluster bezel, then move the needle counterclockwise until it sits back on the stop pin.</TD></TR></TABLE>
did this. work now.
THANKS EVERYONE! :D
did this. work now.
THANKS EVERYONE! :D
