Steering wheel shakes/vibrates while braking
Old Apr 27, 2007 | 10:30 PM
Egonamikal88's Avatar
Default Steering wheel shakes/vibrates while braking
As noted, when Im on the freeway or street going from 45-80 and then press on my brakes, the steering wheel shakes real hard . What the hell could this be? My eagle talon use to do it too, but not as much as the rex. Any info would be cool.
Old Apr 27, 2007 | 10:40 PM
turbodcivic510's Avatar
your brake rotors are warped from age, and intense heating and cooling.
have them resurfaced, or replace the rotors.
Old Apr 27, 2007 | 10:42 PM
.Manny.'s Avatar
Touching My Member
Default Re: (turbodcivic510)
check your radius arm bushings. i redid my brakes and it still did it.
i put in new innovative poly bushings and the shaking went away. just do both, brakes and bushings
Old Apr 27, 2007 | 11:31 PM
Default Re: (.Manny.)
Thanks guys!!! Im gonna do that. I was actually thinking of replacing my rotors and brake lines, but now Im going to do the bushings too.
Old Apr 28, 2007 | 12:08 AM
95lscivic's Avatar
Default Re: (Egonamikal88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Manny. &raquo;</TD></TR><TR><TD CLASS="quote">check your radius arm bushings. i redid my brakes and it still did it.
i put in new innovative poly bushings and the shaking went away. just do both, brakes and bushings </TD></TR></TABLE>
good call, but i honestly would just get oem honda bushings as aftermarket bushings are often squeeky and only last a couple years. I know from experiance.
Old Apr 28, 2007 | 01:10 AM
brandoom's Avatar
An Hero
Default Re: (95lscivic)
Get an alignment too. That **** worked wonders on my shaky handling. Brakepads and rotors too! Everything should be less than $140.
arielb1
May 23, 2009 09:09 AM
JDM_rolex
18
Oct 7, 2007 08:30 AM
JDM_SOHC
12
Dec 1, 2005 09:33 AM
Beave0101
Mar 29, 2004 04:58 PM
bren1339
16
Oct 15, 2003 01:08 PM
