Fixing The 4th Gen Cup Holder With A Paperclip
Old Apr 27, 2007 | 09:10 PM
TylerC161's Avatar
Default Fixing The 4th Gen Cup Holder With A Paperclip DIY
This is for all those who are lucky enough to have the cup-holder in their Prelude console, but the pin lock went somewhere and now the lid stays open constantly.
As long as you have the original cup-holder and the small metal pressure plate that holds the now missing pin lock in place, you can make your own replacement pin lock. This isn't rocket science people. You can do this. It works. I did it. I just did it again and it still works.....and I just did it one more time.
You will need:
One LARGE metal paper clip. (NOT the cute, colored, plastic coated ones) (A small paper clip will work but it's not real sturdy)
Needle-nose pliers.
Tape measure or ruler.
Measure the paper clip to 1 & 1/8ths inches. Score it or mark it at that measure. Using the cutter part of the pliers, cut the paper clip at the mark.
Put about 1/16th of the end of the paper clip in the pliers, while holding the pliers closed on the end of the paper clip, push the paper clip straight down. Do the same for the other end until you have a clip that looks like the one in pic (#1)
Put one end of the now bent paper clip in the hole (#2) and the other end in the track groove (#3)
Put the pressure plate on (#4) and tighten the screw. (This plastic strips out easy, so don't over tighten)
If you did it right, your cup holder should stay closed when you push it down and should open when you push it again.
sorry if its a repost
Old Apr 27, 2007 | 09:22 PM
BB1LOViN's Avatar
Default Re: Fixing The 4th Gen Cup Holder With A Paperclip DIY (TylerC161)
thanks!just this week my cup holder messed up -_-
Old Apr 27, 2007 | 09:24 PM
Diao's Avatar
tyler you are a GENIUS
i didn't think you even had the lid to your cup holder though, lol
Old Apr 27, 2007 | 11:54 PM
91ED7Si's Avatar
Default Re: (Diao)
magieverin up some **** is tight
Old Apr 28, 2007 | 04:56 AM
ProjectTib's Avatar
i got a 4th gen... how can i get a cup holder in my lude?!? lol
Old Apr 28, 2007 | 05:34 AM
slammed95lude's Avatar
Default Re: (ProjectTib)
I went and ordered a cup holder..... If I only knew then what I know now
Old Apr 28, 2007 | 06:18 AM
The Birdman's Avatar
Good fix...though I for some reason think this has been posted here before....not sure
either way
Old Apr 28, 2007 | 06:19 AM
mgags7's Avatar
either way
woops that was me....wrong name logged in
Old Apr 28, 2007 | 12:35 PM
MLBZ521's Avatar
Default Re: (Diao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Birdman &raquo;</TD></TR><TR><TD CLASS="quote">Good fix...though I for some reason think this has been posted here before....not sure
either way </TD></TR></TABLE>
Probably has, considering it is someone elses How-To. I've had this linked saved for the past few years.. Tyler, if you're going to copy someone, give them credit.
http://home.mindspring.com/~re....html
Old Apr 28, 2007 | 03:41 PM
TylerC161's Avatar
Default Re: (MLBZ521)
I didnt make this up, and i never said i did.
In fact, in the original post I said "sorry if this is a repost". Ergo it would of been posted before; meaning it couldnt of been me that made this.
I dont know WHO did it, I just saw it on another thread, copied, and pasted.
Its a good writeup none the less.
zsudz922
Group Threads
May 23, 2009 09:10 AM
B18 Piston
Oct 31, 2008 07:34 PM
dgkdiligan
Jul 27, 2008 09:04 AM
drifter_for_life06
Jul 8, 2005 09:10 AM
babyviper97
Jun 10, 2003 08:49 PM
