***EG radiator on EF***
My radiator has a hole on my EF......so im swapping it out.......i have a EG radiator on hand,,,i was wondering if theres a way i can mount this one with some modification.....and will it work with my DOHC ZC.......
Pics and advise would be higly appriciated!
Just gotta cut a bit of the lower rad support out and it'll drop right in. Rad can only sit in one position for the hood to close properly and I'm using a 10" electric fan and have had no issues.
If you do go this route you'll want to make a metal protector to cover the other half to prevent crap coming into the engine bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by firebane »</TD></TR><TR><TD CLASS="quote">Just chillliln.. held in place by upper rad hose :D</TD></TR></TABLE> that doesnt seem reliable or safe, but you can't argue with results, i was thinking about doing that; but i had mine tilted...
innovative xmember here i come
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote"> that doesnt seem reliable or safe, but you can't argue with results, i was thinking about doing that; but i had mine tilted...
innovative xmember here i come</TD></TR></TABLE>
I have seen a lot of people do it that way, not that I would suggest it.
We also sell them for a great price
innovative xmember here i come</TD></TR></TABLE>I have seen a lot of people do it that way, not that I would suggest it.
^^ your forever trying to advertise your radiator. Hypocryte!! Every time a Radiator thread pops up or downpipe fitment issues you post pictures of your ebay radiator and suggest that they buy it. Get the Full-Race bar and half rad. Super expansive but well worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker »</TD></TR><TR><TD CLASS="quote">^^ your forever trying to advertise your radiator. Hypocryte!! Every time a Radiator thread pops up or downpipe fitment issues you post pictures of your ebay radiator and suggest that they buy it. Get the Full-Race bar and half rad. Super expansive but well worth it. </TD></TR></TABLE>yo ***** bag the guy is tring to get his name out their and sell some parts and stuff no need to be a ******* and do the predicable h-t thing and be a dick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">
We also sell them for a great price </TD></TR></TABLE> What part of the radiator support do i have to cut....can i see a pic. Where can i score one of those brackets.....is it DIY.
Nice hood prop
i too have an eg rad and cut my rad supposdt a bit but i also biut some metal and welded it so its still stiffen and not jsut a flimsy piece of metal
Nice hood prop
Note that every thread I pop into, I help as well. I sell radiators big deal, look at my sig, you could learn that with out me saying a word. Not like I pop in threads and say my radiators are better then any other companys. They are well prices, that is all. And a lot of guys don't like to run aftermarket crossmembers because then they can't run in certain classes.
For everyone that has called me from this thread, there is not a radiator yet made to be the same size as an eg half size radiator but shorter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Jap*****" »</TD></TR><TR><TD CLASS="quote"> What part of the radiator support do i have to cut....can i see a pic. Where can i score one of those brackets.....is it DIY.
The bottom part, where the tabs mount to. This will bring the radiator more forward and down. If you know how to cut metal and have the tools, its not to bad.
</TD></TR></TABLE>The bottom part, where the tabs mount to. This will bring the radiator more forward and down. If you know how to cut metal and have the tools, its not to bad.
The bottom part, where the tabs mount to. This will bring the radiator more forward and down. If you know how to cut metal and have the tools, its not to bad. </TD></TR></TABLE>Does anyone have a pic of the cut rad. support cause mine sits right but its bearly gettin in the way of the hood closing.
i did mine the other day i just cut it completley out (the width of the diameteR)
then i welded a support bar across and welded 90deg angle tabs to hold the rad
every pissible angle
i put mine in for my dohc zc tonight, didnt mount it, hoses hold it in place. Also didnt have to cut the radiator support, and im using a 14" slim fan, and hood still closes.
For everyone that has called me from this thread, there is not a radiator yet made to be the same size as an eg half size radiator but shorter. </TD></TR></TABLE>
actually i have one that i got from an 87 yugo its half size, dual core and i pretty much made my own upper brackets and had the inlet/outlet rewelded check my project thread link in my sig for pics. the downside is its much easier to find a eg radiator then a 87 yugo radiator but its just another option
i used to run that dual core rad, it was tight but worked.. the EG radiator neck is fcking gay, i think this was a del sol rad..
crossmember was spaced down an inch and it was jammed between the x-member and the front piece, with some rubber so it wouldnt rub.
now i run the full race bars plus their half rad, its the best!
I'm using a jimfab front xmember
Cut off the old radiator/evaporator bracket. Used a peice of aluminum angle stock from Home Depot and drilled 2 holes for the bottom mounting tabs. Then I used 2 rubber bushings and bolted it to the car.Hangs lower, but with the Wings West bumper or an aftermarket front lip you can't tell.
Here is a front view.
