problem with autometer a\f gauge
ok heres the deal i hooked up my gauges and they all light up fine. I dont have the signal wire on the a/f gauge hooked up to anything but whenever i press the horn the gauge goes crazy and all the lights light up. I thought it might be feeding back through the ground so i changed the ground and it still does it.So any ideas would be great help. Also shouldnt my oil pressure gauge come up to zero when i turn the key on? Now it just stays down below zero. thanks for the help
mine goes to zero after but mine does the same thing as you i just press on the horn and the air fuel goes crazy..lol i really don't know.!!!
but i heard, because we tried it on another car and wasn't working also..so i think it's defect....and on the other car with a different air-fuel it worked..so it's probaly defect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrX-WoRlD »</TD></TR><TR><TD CLASS="quote">mine goes to zero after but mine does the same thing as you i just press on the horn and the air fuel goes crazy..lol i really don't know.!!!
but i heard, because we tried it on another car and wasn't working also..so i think it's defect....and on the other car with a different air-fuel it worked..so it's probaly defect</TD></TR></TABLE>
defected????? mine works fine. mine does the same thing when u honk but only when my car is off. do you have the 12V connected?
mine use to go crazy when i hit the brakes or turned on the lights. but i just switched the ground to the neg. on the battery and it worked fine.
try that
try that
this is funny mine does the same thing when I honk it goes wonky
, I have switched grounds as well as the power source and it still does it oh well. Just dont look at it when you honk
Jays91DXhatch
Jun 7, 2004 09:20 PM
Mike813
Jun 4, 2004 08:28 AM
