this is my car trying to turn on after mpfi swap why wont it go??????video inside!!!
Old Apr 27, 2007 | 07:33 PM
jo7man4's Avatar
Default this is my car trying to turn on after mpfi swap why wont it go??????video inside!!!
check it out it cranks and cranks and i here a explosion in the combustion chamber like its about to start but it doesnt check it out http://www.youtube.com/watch?v=FmyT8b36GZ4
Old Apr 27, 2007 | 07:41 PM
CalNacker's Avatar
Default Re: this is my car trying to turn on after mpfi swap why wont it go??????video inside!!! (jo7man4)
well a couples questions i guess... i just got done with mine and it runs perfect. after i fixed a couple things. did you switch distributor? double check all your wiring, because i bet you have some wires mixed up at the injectors, or down on the harness side of tha ecu. sounds like your not getting spark,?
throwing any codes?? Check on the 2 white wires on the dist. and swap those and try, they look the same.
Old Apr 27, 2007 | 07:47 PM
jo7man4's Avatar
yes switched dizzy to 1.6 si dizzy i double checked my wiring it looked good to me but ill check a third time not throwing any codes what so ever i have swapped around the the two white dizzy wires so i dont got any idea what else it could like i said ill check the wiring again
Old Apr 28, 2007 | 07:50 AM
jlicrx's Avatar
Default Re: this is my car trying to turn on after mpfi swap why wont it go??????video inside!!! (CalNacker)
do you have the ground wires at the thermostat housing connected?
Old Apr 28, 2007 | 08:33 AM
ridin_on_rims's Avatar
sounds the same as my sons car did when he first got it . he was driving it home,the little screw @ the rotor backed out this was @ night so when he put it back in he insltaled it in reverse. it sounded exactly the same . did you remove the cap and rotor? if so check that, if not try starter fluid see if that tryes to start up ,double check your wires it does sound like it out of firing order
Old Apr 28, 2007 | 09:10 AM
blah13's Avatar
Default Re: this is my car trying to turn on after mpfi swap why wont it go??????video inside!!! (ridin_on_r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin_on_rims &raquo;</TD></TR><TR><TD CLASS="quote">if so check that, if not try starter fluid see if that tryes to start up ,double check your wires it does sound like it out of firing order</TD></TR></TABLE>
Agreed, give the fluid a try. If it starts and runs for a few seconds you've got a fuel problem. Wiring, resistor box, bad injectors etc.
I would almost say its just bad firing order but it should still be combusting it'll just sometimes sound like its coming out of your intake.
If you pull the plugs do you smell fuel in each cylinder? I also assume you've replaced the basic parts, plugs, wires, cap/rotor?
btw for the video, makes things easier
Old Apr 28, 2007 | 09:56 AM
jo7man4's Avatar
when i pulled the plugs yesterday yes i smelled fuel and i didnt replace the wires spark plugs i did replace whole dizzy brand new cap and rotor i checked with a light tester seems that im not getting power to my injectors and all my sensors in my engine bay i get check engine in my cluster but when i go to check the led in my ecu it doesnt blink at all even when i try to turn the car on and crank it nothing im thinking i have a bad ecu
Old Apr 28, 2007 | 09:58 AM
Jonknee's Avatar
Default Re: (jo7man4)
Firing order correct?
Old Apr 28, 2007 | 09:59 AM
jo7man4's Avatar
is there anyone that can help me???near my area that has done this im panicking and my dads on my *** about the car he keeps saying it cant be done he is an old skool mechanic but i knw it has been done and can be done just i cant do it by myself
Old Apr 28, 2007 | 10:06 AM
jlicrx's Avatar
have you checked the main relay?
Old Apr 28, 2007 | 10:48 AM
90IntegraGS1.8L's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the main relay?</TD></TR></TABLE>
If it was the main relay it wouldn't turn over at all just an fyi!
Old Apr 28, 2007 | 11:53 AM
blah13's Avatar
Default Re: (Mr.P1nk)
If you can, swap out the ecu and see if its that. If not then your going to have to recheck all your wiring. From the video it sounds like maybe only 1 cylinder is firing so if you were not getting power to the injectors, find out if its all of them. Trace the wiring back the resistor box (perhaps try a different one here as well) and run them all the way back to your ecu to make sure theyre in the right slots.
Where did you get your mpfi directions from?
The link for the directions I used isn't up anymore, so either search for a current one or if someone here can post up one so you can cross reference yours and make sure your directions are correct.
Old Apr 28, 2007 | 12:08 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">If you can, swap out the ecu and see if its that. If not then your going to have to recheck all your wiring. From the video it sounds like maybe only 1 cylinder is firing so if you were not getting power to the injectors, find out if its all of them. Trace the wiring back the resistor box (perhaps try a different one here as well) and run them all the way back to your ecu to make sure theyre in the right slots.
i agree with this.. it sounds like your car wants to start because its only getting fuel to one cyinder or something. definitely recheck your wiring.. did you install a resistor box and all that for it? did you check all the cylinders for fuel? or just one?
and make sure all your spark plugs are firing, if you havent already.
check those things and dont listen to your dad.. sometimes they just dont know what they are talking about..
Old Apr 28, 2007 | 12:33 PM
welfarepc's Avatar
just ignore me
Old Apr 29, 2007 | 03:57 PM
jo7man4's Avatar
turns out that i had a bad fuse so its running now yay!
Old Apr 30, 2007 | 06:57 AM
sanimalp's Avatar
$cat /dev/urandom
which fuse was it?
thedudefromjerz
Feb 17, 2008 06:33 PM
jo7man4
15
Apr 28, 2007 09:53 AM
lutronluvinek9
Mar 30, 2007 01:45 PM
93NTEGLS
13
Mar 4, 2007 03:05 PM
CHAPY
Apr 15, 2005 09:03 AM
