Took the 617WHP EK Out To Irwindale Last Night... Ok Results......
Old Apr 27, 2007 | 06:29 PM
NOKTURNALCARCLUB's Avatar
Default Took the 617WHP EK Out To Irwindale Last Night... Ok Results......
Here are 2 videos from last nights passes and some timeslips of the runs....
Old Apr 27, 2007 | 06:36 PM
civicjdmb16a's Avatar
Default Re: Took the 617WHP EK Out To Irwindale Last Night... Ok Results...... (617WHP)
nice times! how much psi?
Old Apr 27, 2007 | 06:38 PM
nonvtecallmotor's Avatar
Default Re: Took the 617WHP EK Out To Irwindale Last Night... Ok Results...... (civicjdmb16a)
Seems kinda slow to me....
Old Apr 27, 2007 | 06:42 PM
1st gear - 14lbs, 2nd gear - 18lbs, 3rd & up - 25lbs @ Irwindale track.... Dyno'd at 29lbs for 1/4 mile...
Old Apr 27, 2007 | 06:45 PM
miller's Avatar
Default Re: Took the 617WHP EK Out To Irwindale Last Night... Ok Results...... (nonvtecallmotor)
it does seem slow for the power level.
Old Apr 27, 2007 | 06:52 PM
crx2nr822's Avatar
Default Re: Took the 617WHP EK Out To Irwindale Last Night... Ok Results...... (miller)
Was it your first time at the track with the car? Did you drive?
Old Apr 27, 2007 | 06:56 PM
PHDZINE's Avatar
Your 60ft not that bad...but your MPH really sucks if you do have 617WHP. You should be around 6.9-7.0 et and around 110MPH with that kind of power.
Old Apr 27, 2007 | 07:00 PM
not my first time at this track.. Each week times are improving as im getting the feel of the car and the gears.... I know i can hit a lower 7 on a good run, that is if i dont miss shift and ****!
Jerry ran the 7.2 without doing a burnout, they didnt wet the floor for it!
Old Apr 27, 2007 | 07:59 PM
Rage Cayman's Avatar
Default Re: (617WHP)
With that kind of power,there is no doubt that the motor was put together correct, but why not invest in an ENGINE MANAGEMENT SYSTEM such as MOTEC or AEM etc . You would enjoy your ride more cuz you or your tuner would have control of all that wheel spin to transfer power to the trach which will in turn shows with a better time slip.
Good job
Old Apr 27, 2007 | 08:05 PM
whoa its len 2's Avatar
Get those 7.00's.
Old Apr 28, 2007 | 03:32 AM
allstokhonda's Avatar
102mph is good for low 7s. Turbodav, on here, went 7.16 @ 102mph with 16psi(around 400whp).
Just get out there and practice. You'll get there. Your 60fts'are great.
-Chad-
Old Apr 28, 2007 | 05:16 AM
Turbo-charged's Avatar
Default Re: (allstokhonda)
60's decent but 330 is 4-4.5 tenths off. is it spinning or do you need to put more power down after first?
Old Apr 28, 2007 | 07:24 AM
ATYPR's Avatar
Default Re: (Turbo-charged)
Something is not right with your car.
My car is 2600lbs with me in it and traps 97mph in the 1/8 with 398whp.
Old Apr 28, 2007 | 08:59 AM
Adriano's Avatar
Default Re: (FUCATYPR)
The mph seems low, it could be because of the staged boost. My car with 550whp weighting 2550 usually traps 110-111 mph in the 8th.
Adriano
Old Apr 28, 2007 | 09:14 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Adriano)
mine was like 107 108 in the 1/8th.
Old Apr 28, 2007 | 04:12 PM
DJsilkyjr's Avatar
need to take it on the 1/4 and see how it does their
Old Apr 28, 2007 | 06:48 PM
Stealth Si's Avatar
Is it just me, or does nobody out in Cali do the 1/4? What's up with the 1/8 stuff?
Old Apr 28, 2007 | 06:56 PM
Only local track for me is Irwindale and it only has the 1/8. Believe me if i had easy access to a 1/4 mile track i'd be there at least twice a week.
I'm still getting the feel of the car including the launch so i should hit better numbers as i progress... I know i'll hit a good 1/4 mile because my setup is all top end power!
Old Apr 28, 2007 | 07:02 PM
Stealth Si's Avatar
Well, it still looks good man.. Keep it up, and get more wheel time, lol. You'll get it.
Old Apr 28, 2007 | 10:20 PM
PremierS372's Avatar
Default Re: (Stealth Si)
does seem a little low. i make about the same power and i run 6.9 @107 in the 1/8th
i think, just practice and youll get it.
Old Apr 29, 2007 | 07:27 AM
tony1's Avatar
Default Re: (DJsilkyjr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJsilkyjr &raquo;</TD></TR><TR><TD CLASS="quote">need to take it on the 1/4 and see how it does their</TD></TR></TABLE>
If you don't go fast in the 1/8th, you won't go fast in the 1/4. You can pretty much figure your 1/4 mile times by the 1/8th times. There's a lot more fluctuation in the first 1/8th mile than there is in the 2nd.
Old Apr 29, 2007 | 09:20 AM
seen4ever's Avatar
Default Re: (tony1)
MPH seems way off.
although if 600whp equals 102mph, then what am I putting out at 24psi when i ran 105mph?
looks like you are having the same issues I am, getting the power down to get the 330 lower.
Old Apr 29, 2007 | 09:25 AM
tony1's Avatar
Default Re: (seen4ever)
600whp should get you well over 110 in the 1/8th.
Old Apr 29, 2007 | 09:43 AM
alpha's Avatar
What clutch are you running? Is it slipping?
Old Apr 29, 2007 | 09:50 AM
miller's Avatar
Default Re: Took the 617WHP EK Out To Irwindale Last Night... Ok Results...... (alpha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpha &raquo;</TD></TR><TR><TD CLASS="quote">What clutch are you running? Is it slipping?</TD></TR></TABLE>
I was thinking the same thing.
Also have you ever had the car on a different dyno then the one originally tuned on?
