134a AC EXPERTS... NEED HELP!!!
i have a 98 civic cx with ac. everything was functional last summer. i turned it on this year for the first time to discover hot air blowing. after looking around my engine bay, i had discovered that one of the little aluminum lines had snapped in half. it is one of the 2 lines that connect the little tin cup wit the switch to the bottom of the condenser. (located by the driverside headlight)
i got a new line, and im about to bolt it on.
my question is what do i do next? assuming there are no leaks, will it be safe to just fill it with 2 cans of 134a and go? or will i also need to put oil into the system?
or am i completely wrong and will have to go through a whole procedure that i am not aware of?
the right way would be to evacuate the rest of old freon. then get it vaccumed to remove any moisture. when you refill it you can get the cans that come with oil in them already,if your not using the machine.
so do the regular cans of 134 they sell all have oil in them? because ive never seen any that say "with oil" on the can.
however i have seen smaller cans of seperate oil, and it seems they work the same way through the low pressure release.
all i got to say is do it right the first time, it will cost more money if you destroy your compressor b/c you have moisture in the line.
They do sell r134 with oil mixed in it. Its usually the ones that are a bit more expensive. But read the back under the contents. it will specify what is in it.
yeah you can always add the oil seperate, but no if the can does not say it then there is no oil in it. if you go to your local parts store look for the recharge kit. it is in a tall white can, you just hook it up to the high side, hold the can upside down, and with the car running you fill it up. those come with oil in them already. should be like 20 bucks
Get it done right the first time!
Have an a/c shop evacuate the system to draw out any ambient moisture in the system. How long has system been open like that. You may have to replace the drier also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">Get it done right the first time!
Have an a/c shop evacuate the system to draw out any ambient moisture in the system. How long has system been open like that. You may have to replace the drier also. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiX »</TD></TR><TR><TD CLASS="quote">umm dont listen to him, you hook it up to the low side, sure it was just a error.</TD></TR></TABLE>
yeah did not remember exactly which side
I give this man two
for this responce and I am a certified a/c tech
If its been a week since you noticed it and god knows how long before that and your going to keep the car, get a new drier.
I give this man two
stegs
Jul 1, 2011 07:44 PM
