TCS light switch
Old Apr 27, 2007 | 04:52 PM
mnorrell's Avatar
Default TCS light switch
ok, i just bought a used 02 honda accord...When i drive the TCS light ocasionally turns on. I know the light stands for traction control system, but i have two questions. First, what does the TCS do? Second, why do you think this is happening and is it alot to fix or a big problem?? Thanks alot for all your help
Old Apr 27, 2007 | 07:36 PM
BLKFLSH's Avatar
Default Re: TCS light switch (mnorrell)
The TCS light will come on any time the system detects wheel spin. If the road is wet, when you take off from a stop it can happen easily. If the light is coming on when the road is dry, and you are not accelerating hard, there is probably a problem with the system. The TCS system will apply the brakes to the wheels when they start to loose traction. The TCS button on the dash will turn the system off, but every time you turn the car off, then back on, the TCS will be back on again.
Old Apr 29, 2007 | 04:30 PM
mnorrell's Avatar
Default Re: TCS light switch (BLKFLSH)
thank you very much....the road was wet so maybe that is it....say its a worse case senario and it blinks when the road is dry and im not accelerating what do i have to do to get it fixed? does it cost alot? lastly, the TCS button on the left of the wheel, if i have the light turned off and will the TCS still come on if the wheels spin?
thank u soooo much
Old Apr 30, 2007 | 05:06 PM
mnorrell's Avatar
bump
Old Apr 13, 2013 | 11:51 AM
larrybonnell's Avatar
Icon2 Re: TCS light switch
I just joined and am not sure I am doing this correctly. But I need to know where the switch is on a 2002 Acura TL to turn on the TCS.
Old Apr 13, 2013 | 01:07 PM
NZXTInerTia's Avatar
Well this post is seven years old..
It should be on your dash, most likely near the cruise control button.
Old Apr 13, 2013 | 07:12 PM
MAD_MIKE's Avatar
MM Gruppe B
These guys may know> Acura TL, RL & ZDX .
$EP3CIVIC$
Feb 16, 2012 05:27 PM
RedHonda
16
Jan 20, 2010 12:12 PM
jdmrida
Nov 21, 2008 08:58 AM
pacpark4
May 15, 2005 09:59 AM
Brakiss
Aug 17, 2004 01:00 AM
