accord dash lights went out
Old Apr 27, 2007 | 04:45 PM
b_serious's Avatar
Default accord dash lights went out
I recently installed a sony cd basic cd player and everything was good i've done them before not that hard just power ground power switch and speakers, so today i start the car and turn the lights on and the dash lights are out.. the headlights/brakelights,turnsignals are all working. I checked ALL the fuses all are good.
i also took the cd player out and there still not working.
when i turn the lights on the P light turns off in the cluster and so does the little screen that diplays the milage an **** any ideas on what to do now?
2001 accord coupe ex v6
Modified by b_serious at 8:18 PM 4/27/2007
Old Apr 27, 2007 | 06:27 PM
hondaguy00's Avatar
Default Re: accord dash lights went out (b_serious)
i have the same problem in my accord from doin the same thing. I was putting a stereo and the next morning i turned on the switch and no lights. All warning lights work and outside lights, also the dome light. but no dash lights.
Old Apr 27, 2007 | 06:53 PM
b_serious's Avatar
Default Re: accord dash lights went out (hondaguy00)
yup exactly like mine
Old Apr 28, 2007 | 01:41 PM
b_serious's Avatar
bump anyone know ?
Old Apr 28, 2007 | 03:08 PM
TheMuffinMan's Avatar
He knows where you live!
have you checked fuses?
have you checked for shorts in the radio connection?
etc
Old Apr 28, 2007 | 03:44 PM
tearjerky's Avatar
try resetting by pulling the negative battery terminal for a couple minutes...
Old Apr 28, 2007 | 06:58 PM
Tx_Accord98's Avatar
Default Re: (tearjerky)
if you guys shorted something out when installing radios, i am 100% positive that your multiplex is shorted. happened to me as well, but i hadn't found anyone that had the same problem back then. anyway, the multiplex i am talking about is the blue box in the drivers side fuse panel. change that and you won't have that problem again. next time when you install a radio in your honda, make sure that all your wires are covered. especially the illumination wire.
RedRumLoki
Sep 28, 2017 09:51 PM
distra
Apr 20, 2017 11:32 PM
David Stroud
Dec 20, 2016 01:07 PM
ladybender
Jun 21, 2007 10:01 PM
law_teg_92_R
Jun 21, 2005 08:37 PM
