FS: Block, Water pump, Oil pump, Oil pan, BC4 cams, Cat, Header, Rail, Thermostat, Belt, Struts
Old Apr 27, 2007 | 03:16 PM
JerseySiPOS's Avatar
Default FS: Block, Water pump, Oil pump, Oil pan, BC4 cams, Cat, Header, Rail, Thermostat, Belt, Struts
I have a bunch of B-series parts, a couple stock/ modded P30 manifolds, including brand new, rear struts for a 96-00 Civic hatch.
I ship CHEAP UPS GROUND.
PAYPAL PREFERRED or CASH
B18A short block - $125
- stock 81mm bore
- main caps
- windage tray (has cut in it but works 100 percent)
- oil pick up
- rear crank seal
VTEC oil pump - $SOLD
- 2300 miles
VTEC water pump - $SOLD
P72 Oil Pan - $90
- Good condition
Buddy Club 4 Cam Shafts - $SOLD
- approx. 2400 miles
- valve adjustment/check every 6-8 weeks
- good condition
- original owner
Fuel Rail - $20
Thermostat Housing - $35
- Includes thermostat
Hyoshi B18C Timing Belt - $SOLD
- Brand new IN BOX
Tenneco Automotive Struts - $100
- REAR STRUTS ONLY
- Brand new IN BOX
- For 96-00 Civic Hatch-back
Carsound High-Flow Catalytic Converter - $55
- 2.5" inlet + outlet
- no flanges
- 6000 miles
CTR exhaust manifold - $55
- modded collector
- same diameters as Toda header
- pics available upon request
Located in central New jersey
PLEASE PM me. thanks
i.
Modified by JerseySiPOS at 3:48 PM 6/29/2007
Old May 4, 2007 | 02:44 PM
Default Re: FS: Block, Water pump, Oil pump, Oil pan, BC4 cams, Cat, Header, Rail, Thermostat, Belt, Struts
bump
Old May 6, 2007 | 09:55 AM
ar3dd's Avatar
bumpp ttt how much is shipping to 11369 for that block im interested and its a complete shortblock rii?
Modified by ar3dd at 1:02 PM 5/6/2007
Old Jun 9, 2007 | 07:11 AM
bump
Old Jun 9, 2007 | 01:51 PM
GoFastTshirts.com's Avatar
will that oil pan fit a jdm b16a motor ?
Old Jun 9, 2007 | 07:56 PM
HondaCivicSiR1's Avatar
Default Re: (GoFastTshirts.com)
can i get some pics of the ctr header?
Old Jun 10, 2007 | 05:41 PM
Default Re: (HondaCivicSiR1)
pmed
Old Jun 11, 2007 | 07:38 PM
Default Re: (JerseySiPOS)
i still didn't get any pics of the ctr header
Old Jun 12, 2007 | 02:49 PM
^^^ i emailed you the pics. thanks
Old Jun 12, 2007 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerseySiPOS &raquo;</TD></TR><TR><TD CLASS="quote">^^^ i emailed you the pics. thanks</TD></TR></TABLE>i got them thanks and i emailed you back
Old Jul 6, 2007 | 02:30 PM
bump
JerseySiPOS
Aug 4, 2007 08:27 AM
Circuit Star-29
Mar 16, 2006 10:02 AM
