FS: Block, Water pump, Oil pump, Oil pan, BC4 cams, Cat, Header, Rail, Thermostat, Belt, Struts
Old Apr 27, 2007 | 03:14 PM
JerseySiPOS's Avatar
Default FS: Block, Water pump, Oil pump, Oil pan, BC4 cams, Cat, Header, Rail, Thermostat, Belt, Struts
I have a bunch of B-series parts, a couple stock/ modded P30 manifolds, including brand new, rear struts for a 96-00 Civic hatch.
I ship CHEAP UPS GROUND.
PAYPAL PREFERRED or CASH
B18A short block - $125
- stock 81mm bore
- main caps
- windage tray (has cut in it but works 100 percent)
- oil pick up
- rear crank seal
P72 Oil Pan - $90
- Good condition
Fuel Rail - $20
Thermostat Housing - $35
- Includes thermostat
Tenneco Automotive Struts - $100
- REAR STRUTS ONLY
- Brand new IN BOX
- For 96-00 Civic Hatch-back
Carsound High-Flow Catalytic Converter - $55
- 2.5" inlet + outlet
- no flanges
- 6000 miles
Located in central New jersey
PLEASE PM me. thanks
i.
Modified by JerseySiPOS at 3:44 PM 7/3/2007
Old May 4, 2007 | 02:50 PM
Default Re: FS: Block, Water pump, Oil pump, Oil pan, BC4 cams, Cat, Header, Rail, Thermostat, Belt, Struts
bump
Modified by JerseySiPOS at 3:34 PM 5/8/2007
Old May 9, 2007 | 02:43 PM
bump
Old May 9, 2007 | 08:57 PM
cdale's Avatar
hey ill buy the cams.. call me at 707 338 8091
Old May 10, 2007 | 12:34 PM
707the89fu's Avatar
Default Re: (cdale)
pm him johnny
Old Jun 15, 2007 | 04:59 PM
bump
Old Jun 16, 2007 | 06:43 PM
jdmegmong's Avatar
I looked to see if you had a thread for your OEM 1.8 running 12's with negative results. You mind sharing the set up? thanks.
Old Jun 17, 2007 | 08:33 PM
pmed. in person only, sorry.
Modified by JerseySiPOS at 3:04 PM 6/18/2007
Old Jun 20, 2007 | 02:49 PM
bump
Old Jun 22, 2007 | 12:46 PM
hybrid98's Avatar
bump because
oil pump is sold to me
Old Jun 23, 2007 | 08:17 AM
bump
Old Jun 25, 2007 | 02:45 PM
Armed Ferret's Avatar
can you throw a shipped quote to me for the shortblock going to 68005? i can also accept at a business address (with loading dock) at 68113 (offutt air force base) if it's cheaper.
thanks!
Old Jun 25, 2007 | 05:14 PM
pmed
Old Jun 27, 2007 | 09:05 AM
turbo_ls_69's Avatar
pmed
Old Jul 6, 2007 | 02:29 PM
Default Re: (turbo_ls_69)
bump
JerseySiPOS
Aug 4, 2007 08:27 AM
Circuit Star-29
Mar 16, 2006 10:02 AM
