running 2 intake walbro 255 pumps
Old Apr 27, 2007 | 12:08 PM
spoongsr's Avatar
Default running 2 intake walbro 255 pumps
Has anyone ran 2 walbro intake pumps and if so what you do to install them
thanks
Old Apr 27, 2007 | 12:20 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: running 2 intake walbro 255 pumps (spoongsr)
make them fit the sender, run the line through a bulkhead, and run another line to the front.
with all the effort, a big single will do much better but thats just my thought.
Old Apr 27, 2007 | 12:24 PM
tony1's Avatar
Default Re: running 2 intake walbro 255 pumps (boostedcivicsir)
in tank. They will do no good hooked up to the intake.
Old Apr 27, 2007 | 12:27 PM
AllMoToRB18c's Avatar
Default Re: running 2 intake walbro 255 pumps (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">in tank. They will do no good hooked up to the intake.</TD></TR></TABLE>
HA
Old Apr 27, 2007 | 03:05 PM
Bailhatch's Avatar
Default Re: running 2 intake walbro 255 pumps (AllMoToRB18c)
i put 3 in a supra once. it went fast.
Old Apr 27, 2007 | 03:13 PM
tony1's Avatar
Default Re: running 2 intake walbro 255 pumps (Bailhatch)
With 3 intake pumps, is that like ram air?
Old Apr 27, 2007 | 03:18 PM
80884's Avatar
If you hook them up in the intake its like turbo. Of all people I would have though you would have known that Tony. Jeez
I just finished up putting two in a supra - I don't like the idea.
Bosch 044 anyone?
Old Apr 27, 2007 | 03:31 PM
tony1's Avatar
Default Re: running 2 intake walbro 255 pumps (80884)
The bosch 044 is only good for about 50-75hp more than the walbro 255. For the most part, if 1 walbro isn't enough, neither is one Bosch, unless you're right on the border of the walbro not being enough.
Old Apr 27, 2007 | 03:36 PM
Axle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">i put 3 in a supra once. it went fast.</TD></TR></TABLE>
Who sells those brackets to fit 3 of them? I saw a post about it once but couldn't find it listed on the site provided.
Old Apr 27, 2007 | 03:42 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">With 3 intake pumps, is that like ram air?</TD></TR></TABLE>
yes, it has the exact same results. each pump will be hooked up to 2 intake runners, that is why 4 cyl hondas only need 2 pumps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Axle &raquo;</TD></TR><TR><TD CLASS="quote">
Who sells those brackets to fit 3 of them? I saw a post about it once but couldn't find it listed on the site provided.</TD></TR></TABLE>
titan motorsports sells brackets to fit 3 of them but you have to run some hose or something up to the intake. so really its a remote intake pump setup
Old Apr 27, 2007 | 03:55 PM
tony1's Avatar
I wonder who the genius was who decided it would be a good idea to put an intake pump all the way in the back of the car...
Old Apr 27, 2007 | 04:07 PM
Bottle's Avatar
This is what we make.
But this is for the Supra.
Old Apr 27, 2007 | 04:13 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I wonder who the genius was who decided it would be a good idea to put an intake pump all the way in the back of the car... </TD></TR></TABLE>
it's gotta be for weight distribution...silly road racers!
heres the supra one you guys sell all loaded up ready to be wired...I welded some fittings to it, sorry
Old Apr 27, 2007 | 06:31 PM
Axle's Avatar
Default Re: (Bottle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bottle &raquo;</TD></TR><TR><TD CLASS="quote">This is what we make.
But this is for the Supra. </TD></TR></TABLE>
I don't see that on your site separately, only see the whole kit here:
How much is that whole system together?
Old Apr 27, 2007 | 07:46 PM
SPOOLINmatt's Avatar
Default Re: (Axle)
i heard that kit was like 1000$ or something along that line. it has to be atleast $900 from what is shown in the pic making an educated guess and then you factor real world costs.
Old Apr 27, 2007 | 07:50 PM
Axle's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">i heard that kit was like 1000$ or something along that line. it has to be atleast $900 from what is shown in the pic making an educated guess and then you factor real world costs. </TD></TR></TABLE>
I figured as such because AMS' 1200hp-rated fuel kit (with twin pumps) goes for $1,300.
http://www.amsperformance.com/...d=148
I wonder if it's possible to buy just that thing Bottle posted instead of the entire system since I'd need a different rail, already have a set of injectors, etc.
Old Apr 27, 2007 | 08:06 PM
Bailhatch's Avatar
Default Re: (Axle)
I wonder if it's possible to buy just that thing Bottle posted instead of the entire system since I'd need a different rail, already have a set of injectors, etc.</TD></TR></TABLE>
it's right on Titans site. 2 or 3 pump hanger, under mk4 supra then fuel system. its $465
Old Apr 27, 2007 | 08:14 PM
Axle's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">it's right on Titans site. 2 or 3 pump hanger, under mk4 supra then fuel system. its $465</TD></TR></TABLE>
Good find
What, if anything, makes this Supra-specific? Is it too wide or tall for other applications?
Old Apr 27, 2007 | 08:36 PM
tony1's Avatar
Default Re: (Axle)
It'll only fit in a supra, just about everything about it is different from car to car except for the fact that it holds a fuel pump.
Old Apr 27, 2007 | 11:03 PM
The sweed's Avatar
If your engine is demanding more fuel than 1 walbro can deliver and you add another one.. If one fail the car will start and work as usual and when you step on it it will go lean with only one pump working. If you had one big you can just pray it fails when you´re not at wot so you will notice that the pump fails. Just mounting 2 $90 pumps and trust them your $20 000 dollar engine is not something I would feel comfortable with...
Old Apr 28, 2007 | 03:04 AM
Turbocivic94's Avatar
Default Re: running 2 intake walbro 255 pumps (The sweed)
I run 2 bosch pumps, is there way to know if one pump fails. wire them to a safety switch or some kind of light to show that they're not working?
Old Apr 28, 2007 | 05:42 AM
2 0 3's Avatar
Default Re: running 2 intake walbro 255 pumps (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">I run 2 bosch pumps, is there way to know if one pump fails. wire them to a safety switch or some kind of light to show that they're not working?</TD></TR></TABLE>
Hobbs switch ?
I've never used one personally, but i believe with a certain amount of drop in pressure, it will open/close a contact. This can be wired to shut the engine down, if a sudden drop in fuel pressure was to occur.
someone correct me if i am wrong.
Old Apr 28, 2007 | 05:49 PM
fmfkid250's Avatar
I have seen somethign where you can watch current to both pumps.
Old Apr 29, 2007 | 09:45 AM
Suprdave's Avatar
Default Re: running 2 intake walbro 255 pumps (fmfkid250)
You aren't going to be maxing 2 Walbro Pumps out tho...
How often has anyone seen a Walbro Fail? Those things are ******' troopers...
K.I.S.S.
Old Apr 29, 2007 | 04:34 PM
locash's Avatar
Default Re: running 2 intake walbro 255 pumps (Suprdave)
I've seen a few Walbro's fail. Personally, I think they are hit or miss, and I won't be trusting my motor to the inconsistent QC of the Walbro unit. Hell, what can you really expect from a sub $100 fuel pump?
