rear disk brake conversion for eg with gsr brakes..
Old Apr 27, 2007 | 11:01 AM
jus_spooln_wicha's Avatar
Default rear disk brake conversion for eg with gsr brakes..
does anyone have any good links that could help me take off my old drums and replace with these niffty "new" rear disk brakes i have.. and does anyone know if it would make a difference if i put a gsr brake booster on too? let me know..ive got access to a master cylinder also if i need it.. thanx~!
Old Apr 27, 2007 | 01:09 PM
BlueIntegraBoy's Avatar
Default Re: rear disk brake conversion for eg with gsr brakes.. (papa_jon)
There's no need to upgrade the brake booster or master cylinder when just doing a rear disc conversion.
1. Undo the ebrake cables from the ebrake cable.
2. Undo the bolts connecting the LCA and UCA to the trailing arm.
3. Undo the strut bolt.
4. Undo the rubber brake line form the hard brake line.
5. Undo the two bolt connecting the trailing arm bushings to the frame.
6. Undo the toe arm bolt.
7. Drop the trailing arm and ebrake cable brackets from car.
8. Installation in reverse.
Old Apr 27, 2007 | 01:28 PM
EL Vap133's Avatar
Everything you need to know is here: https://honda-tech.com/zerothread/642479
Also, why go through the toruble of replacing a brake booster and not the Master Cylinder?
Old Apr 28, 2007 | 08:43 AM
Default Re: rear disk brake conversion for eg with gsr brakes.. (EL Vap133)
true that..but the booster ive got .. master i gotta pay more for
Old Apr 30, 2007 | 08:56 PM
boostatic's Avatar
it will make a difference if u put on a gsr brake booster and master cylinder...the gsr master cylinder is usually the biggest u can get...they're usually 1inch mater cylinders compared to the 7/8ths or 15/16 that are usually in civics...it will def upgrade your brakes even more
Old Apr 30, 2007 | 11:59 PM
Default Re: rear disk brake conversion for eg with gsr brakes.. (boostatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostatic &raquo;</TD></TR><TR><TD CLASS="quote">it will make a difference if u put on a gsr brake booster and master cylinder...the gsr master cylinder is usually the biggest u can get...they're usually 1inch mater cylinders compared to the 7/8ths or 15/16 that are usually in civics...it will def upgrade your brakes even more</TD></TR></TABLE>
You don't need a larger master cylinder because you won't be pushing more fluid...
Old May 1, 2007 | 12:51 AM
boostatic's Avatar
Default Re: rear disk brake conversion for eg with gsr brakes.. (BlueIntegraBoy)
the bigger master cylinder helps you push more fluid...for increased braking...no???
Old May 1, 2007 | 01:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostatic &raquo;</TD></TR><TR><TD CLASS="quote">the bigger master cylinder helps you push more fluid...for increased braking...no???</TD></TR></TABLE>
You won't be pushing more fluid over the drums. I think if you just swapped a larger master with just the rear disc conversion, you could lock up your brakes real easily.
Old May 12, 2007 | 02:19 PM
how bad is it if i put these brakes on but i dont change out the Proportioning valve ....? any ideas
fryman
Aug 7, 2015 06:49 PM
Ek9andyroo
Sep 9, 2009 12:42 AM
djrico724
Suspension & Brakes
Jun 3, 2008 04:22 PM
Excelerate
Mar 22, 2004 01:42 PM
