2002 TL-S - No Heat - HELP!!!!!
2002 Acura TL-S, I have Comp-Tech USA Headers, Ice Box, Full Exhaust...... Never had a problem with the car. Woke up this morning, let the car warm up in driveway, got in, NO HEAT.
Passenger Side floor NOT Wet
Havent dont any recent work - gonna check anti-freeze on lunch break - what else could it be?
NOT Overheating
Dont want to damage, please let me know what you think.
Much appreciated.
NOT Overheating
Much appreciated.
Probably blockage in the pathway for heat. I am going based off what I knew about my Integra, but there was a pathway for the radiator fluid that ran through the throttle body, and I believe that had to do with providing heat (warming up the incoming air). I am guessing you have some sort of blockage in the throttle body there.
If you know someone mechanically inclined, they could easily take a look by removing the throttle body. Before though, I would suggest getting the Service Manual which will show you what I am talking about.
Otherwise, take it to the Stealer-ship and they will take care of it for you.
is the auto climate control working properly? (IE when you change settings for airflow, they work and there are no error codes when you run the self test)
if the system is low on freon the heater will not work and only outside air will flow. need to check that first to see if the air temp changes and if it does now then their most likely a leak in the system very common with the honda and acura line that use climent control.
their is no such blockage that the last guy was speaking of that would effect the heater and since the tl is on the fly throttle you can zero that out.
one very common problem is the airmix motor under the center right side of the dash. The little motors usually make a grinding noise and fail staying stuck and not giving a tempereature change. I've replaced many of these when I worked at Acura before starting my own business.
it does. I went out at lunch and checked the anti-freeze level in the rad- that was at the neck, the overflow was fine as well.
went out all weekend and the heat was perfect.
Im wondering if my thermostat might be going bad, maybe giving me a warning.
appreciate the response, thanks much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftdas2000 »</TD></TR><TR><TD CLASS="quote">one very common problem is the airmix motor under the center right side of the dash. The little motors usually make a grinding noise and fail staying stuck and not giving a tempereature change. I've replaced many of these when I worked at Acura before starting my own business.
x2. Very common issue on TL's from this era.
</TD></TR></TABLE>x2. Very common issue on TL's from this era.
Thanks for the heads-up
, i'll have to keep the radio down long enough to listen for sounds, but all is good so far. gonna keep an eye on the engine temp and make sure it doesnt fluxuate, but am prepared incase its the thermostat.
Appreciate the knowledge.
, i'll have to keep the radio down long enough to listen for sounds, but all is good so far. gonna keep an eye on the engine temp and make sure it doesnt fluxuate, but am prepared incase its the thermostat.Appreciate the knowledge.
mkinpwrat12g's
Sep 1, 2005 07:12 AM
