Mid-Atlantic (Sales) VA, DC, and MD
Garage cleaning in md
Old Apr 27, 2007 | 12:31 AM
9_of_10's Avatar
Default Garage cleaning in md
2000 civic si factory airbox and intake arm. lower part of airbox and holes drilled into it. does not affect the airbox aside from a deeper intake sound. $50
96-00 civic dx factory airbox and intake arm. will fit any civic, which has the throttle body facing up. $50
98 civic ex intake arm. $30
99 civic dx exhaust manifold and cat. manifold, cat, and downpipe are complete. was taken off at 75k, replaced with a header. will fit most single cam civics. $150
96-00 civic e-brake cover. eliminates the armrest. dark grey color. $20
90-91 integra ls bare intake manifold. $30
98-00 accord coupe mud guards. $40
98-00 accord v6 hub caps. painted black. $40
98-00 accord. kaminari front lip. made of fiberglass. has 2 long cracks. can easily be fixed. painted milano red. $80
99-00 civic radio install kit. includes radio trim and harness adaptor. $20
white wire injectors from b16. $50 for a set
99-00 civic si. factory fuel rail. $25
15'' steelies. 205-65-15. will fit any 5 lug honda/acura. good for winter wheels or full size spare. 3 available. $25 each.
90 integra center caps. for factory aluminum wheels. $10 each.
h22 throttle body, missing tps and map. $50
generic intake for 94-97 accord. just 3'' piping no filter. $20
pioneer gex fm903xm. tested, working unit. was removed from truck before being traded in. all wiring is included along with trek antenna. can be added to any factory or aftermarket stereo, or can be used with any xm ready pioneer radio. sold as-is. $80
stock clutch and flywheel out of a 99 civic dx, d-series 20k on the set-up. will fit most single cam hydro trannys. includes throw out bearing. $80
one tire. brand is hercules, tires size is 205-55-16. good amount of tread left on the tire. $35
2 manual transmissions for a H22 or accord. One has a LSD and one does not.
The one with the LSD is $800.
And the one without the LSD is $500.
Hasport mounts for a H22 intoa 92-95 or 94-01 integra. new, used once to test fit motor in car and then it was taken back out. $400
Brand new exedy stage 3 clutch for H22. Never used. $375
Brand new fidanza flywheel for a h22. never used. $200
Two used pioneer 12 disc changers:
Pioneer cdx-p1210. Just the changer, does not include the wiring or mounting brackets. $50. Pioneer cdx-p1280. Includes the wiring and moutning brackets. $100. Both have been tested and are in working order.
16'', 5 spoke wheels off a 98 prelude. rims are painted black. tires need to be replaced. only 3 available. good for winter wheels, full size spare, or put some slicks for the track. will fit any 5 lug honda/acura. $50 each, 2 available.
pick up only
reply to me thru email: brian.sk2@gmail.com
GermyLin
Feb 10, 2019 08:34 AM
S1LENT94D00R
Texas -OK -LA (Sales)
32
Mar 29, 2012 09:05 AM
EL-Driver
Feb 26, 2002 06:54 PM
