Who's made their own header with a MIG?
Old Apr 27, 2007 | 12:08 AM
MidEngine4Life's Avatar
Default Who's made their own header with a MIG?
I've seen some of the turbo manifolds on HMT welded up with a MIG. But I'm specifically interested in hearing from any who've made their own NA race header. I was hoping to see or hear about others who've done the same, success or failure.
Old Apr 27, 2007 | 12:17 AM
null.'s Avatar
Default Re: Who's made their own header with a MIG? (MidEngine4Life)
i have had a friend make one like a profab header, he just grinded down the welds later so it can look pretty. so success.
Old Apr 27, 2007 | 03:31 AM
Flashmn's Avatar
Default Re: Who's made their own header with a MIG? (null.)
I did one with a 220V basic mig, worked.. though I updated to a tig made header now.
Old Apr 27, 2007 | 06:52 PM
Default Re: Who's made their own header with a MIG? (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">I did one with a 220V basic mig, worked.. though I updated to a tig made header now.</TD></TR></TABLE>
How did it hold up? I'd be using a Lincoln SP-135+, I wouldn't really care about it looking pretty. But function would be a priority! I've practiced a bit and the hardest part seems to be welding the tubes to the flange, it's hard to keep the heat mostly on the flange and keep it from burning through the tubes.
Old Apr 27, 2007 | 07:24 PM
*Boostwerks*'s Avatar
There shouldn't be any reason why it wouldn't work. I actually MIG pipe hand rails at work sometimes.
I've thought about building one out of mild steel els just for ***** and giggles.
Some advice on welding small pipe with mig: I've found that filling the bevel with short pulses of the trigger to overlay beads works much better than a constant bead. you can actually build TIG like beads, that are flush with the surface of the pipe. Penetration depending on your settings, can also be just as good as TIG.
I'd reccomend practicing on some spare pipe, and then giving it a shot!
Old Apr 27, 2007 | 07:59 PM
Bailhatch's Avatar
Default Re: (Boostwerks.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">There shouldn't be any reason why it wouldn't work. I actually MIG pipe hand rails at work sometimes.
I'd reccomend practicing on some spare pipe, and then giving it a shot! </TD></TR></TABLE>
sorry, but you dont want to weld anything like that except maybe body work. its is weak and not the proper use of a MIG welder. I used to do it but now know better. Also a header made out of pipe is just silly IMO. total overkill and will unnecessarily heat up the engine bay compared to thin tube.
Old Apr 28, 2007 | 05:03 AM
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
sorry, but you dont want to weld anything like that except maybe body work. its is weak and not the proper use of a MIG welder. I used to do it but now know better. Also a header made out of pipe is just silly IMO. total overkill and will unnecessarily heat up the engine bay compared to thin tube.</TD></TR></TABLE>
Actually...A certified welder for the Air Force taught me about this technique. Theres nothing wrong with doing it, if your using the right WFS, and voltage.
And I was talking about making a turbo manifold with the pipe. He can easily use this same method to make a thin gauge header. More than likely, it will prevent him from burning through.
Old Apr 28, 2007 | 07:47 AM
hootiehoo's Avatar
i dont know man, the start and stop points of a mig weld are the weakest points, or at least have the worst penetration when looked at an acid etched cross section.
this is the main reason why you overlap the start and stop point of a bead with mig.
at any rate, mig welding is totally fine. IMO its harder, as with the thin tubing, you dont have the precise control over the arc and filler like you do with tig, and its easy to make a mess quick.
Old Apr 28, 2007 | 08:02 AM
Bailhatch's Avatar
Default Re: (hootiehoo)
yup, you are creating unwanted stress risers at every seam. It just isnt how you use a MIG machine regardless if GI Joe showed you or not.
Old Apr 28, 2007 | 08:43 AM
Bakeoff's Avatar
with the flange to pipe joint, it's just like doing exhaust piping, using a thick flange. Get some heat to the flange, let it pool, walk it over to the pipe and back qickly. Just spend most of your time on the flange, rocking it into the pipe for half the time you're spending on the flange.
Old Apr 28, 2007 | 08:54 AM
postman's Avatar
Default Re: (Bakeoff)
the thin will draw the puddle from the thick. its all about the angle of your gun
Old Apr 28, 2007 | 04:02 PM
arcboy's Avatar
New User
Definately don't want to do the pulse technique.
The certified Air Force dude needs to retire.
To prevent from burning through requires the right technique which include manipulation, gas, wire, etc...
If you weld it with GMAW and then start grinding and smoothing it this will start to weaken the weld.
The only reason I would suggest this is for body panels but even then you are taking a risk. I do it sometimes because I have to weld many different thicknesses and don't have time to adjust the machine to compensate for the thinner materials.
Old Apr 29, 2007 | 02:29 PM
Default Re: (arcboy)
Good tips, thanks guys
Old Apr 29, 2007 | 03:01 PM
redzcstandardhatch's Avatar
something different
Default Re: (MidEngine4Life)
we've made several headers/turbosetups with our MIG welder (before we got a TIG)..
never had a crack. its really in the skill of the welder, and making sure he puts the settings where they need to be
my brother does the technique that bryson talked about sometimes on pipes /tubes where the weld be seen and needs to look good... looks pretty good. i wouldnt do it on much more than charge piping though.
never had one cracked bead on anything though.. probably done 100 exhausts, 15 turbo setups, and TONS of other stuff with the MIG.. we love da MIG.. haha
itr1244
Welding / Fabrication
Sep 4, 2006 09:04 PM
Ruben19
May 11, 2006 12:13 PM
608 Gangsta
12
Apr 2, 2006 11:09 PM
Mike K
Dec 10, 2004 12:39 AM
A1
Dec 5, 2003 06:51 PM
