Speedometer not working - d16y8
Old Apr 26, 2007 | 09:07 PM
bassysingh's Avatar
Default Speedometer not working - d16y8
So i did a tranny swap and at first the speedo was working off and on (thought maybe some water had to dry up from when we cleaned the casing and it may have gotten inthe the sensor). Anyhow, it finally just stopped. I swaped the current speed sensor out with the one that was in the original transmission (never had a problem with this one), still not working. How do i tell if the problem is the speed sensor or something else? And if it is something else, what could it be?
Old Apr 26, 2007 | 09:14 PM
EJ1_Sleeper's Avatar
Default Re: Speedometer not working - d16y8 (bassysingh)
did you try a diff cluster? thats my issue at hand. My speedo is retarded and only works 1/2 the freakin time. Hopefully tomorrow i can find another one. Freakin U-Pick-It had NO CLUSTERS...
Old Apr 26, 2007 | 09:23 PM
bassysingh's Avatar
Default Re: Speedometer not working - d16y8 (EJ1_Sleeper)
yeah, i was thinking that but not sure how to test and see if the cluster is bad. I don't have the resources to just plug up another cluster, and like you said, u-pull-it doesn't have any....
Old Apr 27, 2007 | 12:41 AM
crimsonv4mpire's Avatar
if it was working partially i would say your vss <velocity/speed sensor> is not in all the way. i had the same problem
xjm92x
Mar 21, 2011 09:10 PM
mikehawk
Nov 5, 2008 10:04 PM
hip_hop_s0ulchild
Mar 1, 2007 03:41 PM
slow4dr
Dec 27, 2004 07:19 AM
