how much to replace a head gasket?
Old Apr 26, 2007 | 07:58 PM
Prudz_lude's Avatar
Default how much to replace a head gasket?
Just an estimate. what are you guys paying or have paid for those who have done this. Also i made a thread this week about burning coolant. Its never burned blue and still has not burned any blue just a little bit of white. Not even clouds of it, just a little. Its an h22 btw. My rings should still be alright right? A new gasket should fix this problem?
Old Apr 26, 2007 | 08:01 PM
Hawkze_2.3's Avatar
Default Re: how much to replace a head gasket? (Prudz_lude)
If your car is not overheating you probably don't need a headgasket. Are you loosing lots of coolant?
White smoke could easily be fuel from your car running a bit rich.
Old Apr 26, 2007 | 09:15 PM
Prudz_lude's Avatar
Default Re: how much to replace a head gasket? (Hawkze_2.3)
its not loosing any coolant from what i can tell. i had it checked at a shop and they said it was fine. the car does not overheat at all. I can drive it hours on end and it does not get hotter. the injectors are really old, i was thinking about cleaning them and having them tested again. How could i fix the car from running so rich
Old Apr 26, 2007 | 09:18 PM
Hawkze_2.3's Avatar
Yeah, good idea on the injectors. Also, an 02 sensor could be bad...and an adjustable FPR and a gauge would help, but it's not needed.
Old Apr 26, 2007 | 09:32 PM
preludefien
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">If your car is not overheating you probably don't need a headgasket. Are you loosing lots of coolant?
White smoke could easily be fuel from your car running a bit rich. </TD></TR></TABLE>
x2
Old Apr 26, 2007 | 09:46 PM
Prudz_lude's Avatar
Default Re: how much to replace a head gasket? (preludefien)
well i have new headers so i am getting a new o2 sensor anyway. injectors i will clean. Also i forgot to mention the car has been withouta battery for a year so i assume the ecu reset itself, correct? if so doesnt the ecu run a little rich for the first little while after its been reset? i think i heard that somewhere but not sure if its true.
Old Apr 27, 2007 | 10:49 AM
Prudz_lude's Avatar
bump
D3vin
14
Mar 14, 2010 08:41 PM
95civic16
Jul 24, 2007 11:09 AM
SLO Sol
Dec 24, 2005 05:44 PM
Eg6_JDM
Aug 20, 2002 06:01 PM
sagaprelude
Nov 10, 2001 02:46 PM
