Help: CRX w/GSR swap *Wiring*
Old Apr 26, 2007 | 06:57 PM
rtnlsltn's Avatar
Default Help: CRX w/GSR swap *Wiring*
I have a CRX with a GSR swap. Previously it was supercharged so it did not need a MAP sensor. I am now running a stock build until i can afford a built boost motor. The guy i purchased my car from hacked up some wires pretty bad and it's hard to tell what they even went to. The component i am most worried about is the MAP sensor. The sensor was removed because of the piggybacks installed, so now im not sure where it hooks up to. If anyone could give me direction as to where the wires or plug should be located it would be a lot of help. He hacked up the harness pretty bad so i'm lost.
Any guidance is appreciated
Old Apr 26, 2007 | 07:00 PM
HamiltonRex's Avatar
Default Re: Help: CRX w/GSR swap *Wiring* (rtnlsltn)
get another harness.
Old Apr 27, 2007 | 10:21 AM
rtnlsltn's Avatar
Default Re: Help: CRX w/GSR swap *Wiring* (HamiltonRex)
thing is...i need the car up by monday when i get mys wap in..
Old Apr 27, 2007 | 10:56 AM
Darkamek's Avatar
pick up a helms manual it should have all the wireing diagrams you need.
Old Apr 27, 2007 | 10:57 AM
Slurp56's Avatar
Your best bet is to consult a service manual. It will have a complete schematic as well as wire colors for identification. If you dont have one, go down to your local dealer and photocopy some pages from the book. Should start in chapter 11 about 30 or so pages in.
Slacker93eg
Sep 12, 2012 09:48 AM
JDM-JAMES
Jul 20, 2008 01:36 PM
SamN
16
Sep 17, 2007 01:02 PM
JDMlyfestyle
Oct 17, 2004 08:13 AM
HKSone
Oct 29, 2003 02:08 AM
