help car smoking!
Old Apr 26, 2007 | 04:50 PM
teamswooop18's Avatar
Default help car smoking!
whats up guys. ok i have a huge prob. i have a 95 integ and is smoking bad. also it smells bad also. my compression is 180 and i have no idea what the problem could be can someone help me please
Old Apr 26, 2007 | 05:04 PM
HXvtec's Avatar
Default Re: help car smoking! (teamswooop18)
is the smoke coming out from the exhaust or from under the hood.
Old Apr 26, 2007 | 05:09 PM
Mistermark's Avatar
where is it smoking from? what colour smoke? what does it smell like? hows your oil level? coolant?
Old Apr 26, 2007 | 06:01 PM
the smoke is comming from the exhaust and is bluish at first then it turns like a grey or blak color at higher rpm's and lags power at 2500 and 3500 tremendously. it feels slow all in all
Old Apr 26, 2007 | 07:31 PM
phan222001's Avatar
blue is oil burning and black is to much gas
Old Apr 26, 2007 | 07:37 PM
ls19integra95's Avatar
Default Re: help car smoking! (phan222001)
first off your in the wrong section, you should have posted it in the integra section and not the civic/del sol one, but as to your problem, it could be a few things, most likely one is you could have bad piston rings and its burning the oil, or you caoul have bad valve stem seal... how many miles are on the engine and pull your spark plugs out and see if they are covered in oil or if they are dry...
Old Apr 28, 2007 | 12:13 AM
Default Re: help car smoking! (ls19integra95)
ok i cleaned the throtle body and no smoking any more but still laging in gears but i just remembered that i adjusted a coolant sensor before and i have a feeling that it is adjusted wrong. it is right below the throtle body with two hoses coming from it
smoked08
19
Aug 30, 2011 09:23 PM
dvd5904
74
Apr 5, 2010 05:49 AM
MYKJDM
Jul 17, 2007 05:10 PM
KustomCrx
Aug 26, 2004 11:16 PM
redteg1
Oct 27, 2002 09:36 PM
