air conditioning help!
ok im not good with AC so someone help me out
I know if the freon gets low the compressor wont engage at all
so on my 92 hatch
I flip the ac on and the clutch DOES engage and the compressor spins does that mean IM full of freon?
no cold air comes out and its getting hot here
so what do I need more freon?
or something else to be checked?
so on my 92 hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Racer X 7 »</TD></TR><TR><TD CLASS="quote">ok im not good with AC so someone help me out
so on my 92 hatch
you can go and pick up one of those freon charge kits at your local parts store.it is the freon can and a gauge included. you can use the gauge to read if you are actually low or not. if you are add until charged.
so on my 92 hatch
i will try that but last time I did that on ,y del sol somethign weird happened it did blow cold air BUT when the compressor was on it SEVERLY dragged the engine down
WAY WAY more than normal
maybe because I charged the system and didnt evacuate prior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Racer X 7 »</TD></TR><TR><TD CLASS="quote">i will try that but last time I did that on ,y del sol somethign weird happened it did blow cold air BUT when the compressor was on it SEVERLY dragged the engine down
maybe because I charged the system and didnt evacuate prior</TD></TR></TABLE>
hmmm...i really don't know, this what i did on my hatch and never had a problem.
ok dod this went and got the quick charge with oil and some kind of leak helper in it and a gauge
when I hooekd the gauge up it was in the green maybe 5 psi low so I topped it off
didnt help
it blows kinda sorta cold but its still hot def not like its supposed to be doing
whats the next thing to check?
didnt help
check out your evaporator, could be filled with dust etc. i would recommend getting a manifold guauge set and seeing your pressures and compare them to specs.
Well unless it was converted to r134 that system is r12 freon. The 2 types are not compatible with one another. the system should be evacuated and have the r134 added to it you might have to have a dye added to check for leaks good luck
dont mean to jack the thread, but where do u put oil in? when i turn the ac on in my 00 si, the motor seriously draggs when the compressor kicks in, but still blows cold air. any ideas?
Guest
Posts: n/a
jesus, gotta love diy freon charges. u have no idea how low your frean sys. is, u have no idea how much to put in. your pressures should be about 200-240 high and 35-50 low, if that helps. the gauge your talking about is low side only. is your comp. clutch cycling alot? on-off.
I had the same problem on my civic a/c would almost stall the motor at idle. But it worked well at 1500 rpm and above. It turned out to be a bad ground near the compressor. The idle controll was not getting the message that the load on the motor had increased. I hope this helps.
Pete
Pete
USA
May 3, 2019 03:28 AM
yoblocher
Jun 28, 2016 08:33 PM
