Question about gas....
okay this may be a stupid question but its better to be safe than sorry. The owner before me put mid-grade gasoline in her car but under the speedometer, it says premium only BUT if its just a 4-cylinder then why does it need to have premium gas in it IF it really does?? I owned a Mitsu Eclipse GST before this and it required Premium gas but that was understandable because it had a turbo on it. So I am confused and any feedback would be great! Thanks everyone!!!
Michelle
Michelle
well then definately you have to put premium only unless you want your car running like a minivan. if you want to avoid problems later on just put premium. what 10-20 cents more a gallon (come on)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie »</TD></TR><TR><TD CLASS="quote">it needs premium gas due to its high compression and its tuned to run on it.</TD></TR></TABLE>
If you run cheap gas in your GSR, your performance and fuel economy will suffer, and you really won;t save anything. It shouldn't harm the engine due to the knock sensor (provided everything is stock, especially the ECU).
yeah you SHOULD and it should be manditory to only use Premium especially on that GSR motor. That's the first time I heard of someone running reg gas on a GSR motor... wowser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 »</TD></TR><TR><TD CLASS="quote">
yeah you SHOULD and it should be manditory to only use Premium especially on that GSR motor. That's the first time I heard of someone running reg gas on a GSR motor... wowser</TD></TR></TABLE>
You'd be surprised at how cheap people can be.
jsantosDC5
11
Aug 5, 2006 03:28 PM
