Need help...
i still dont know what's wrong with my clutch! my clutch pedal goes all the way down to the floor but only when its a hot day and when i punch it. but at night it doesnt do it unless i punch it and then the pedals goes flat to the floor.
To fix the pedal i have to push it in a few times and pull it up from the bottom with my foot. When i push the pedal it doesnt allow my to shift thats how low the pedal is.
what can it be? i posted a comment kindda the same but i culdn't get a good answer. My tuner said the clutch was fine.
99 GSR, Stage 2 exedy clutch, fidanza flywheel
thanks...
thanks...
no, i doubt that its a leak almost everytime i drive my car i check the floor for leaks and latelt i've been working on my car and i havent noticed any leaks.
http://store.summitracing.com/...w=sku
http://replacement.autopartswa...=true
ok so i think it must be the master cylinder so im just buying it. does the brand matter or OEM would be best!??? thanks
Check both your master and slave cylinder. Go down to your pedals.. and feel all the way up on your clutch pedal, you should feel a thin bar. If your fingers get wet from something, you have a leak. As for your other question, when in doubt, go OEM.
Slow Egg
11
Jun 26, 2017 11:25 PM
gsr camel
Sep 13, 2001 12:05 PM
