Ticking noise? Injectors?
Old Apr 26, 2007 | 11:21 AM
boomersz's Avatar
Default Ticking noise? Injectors?
edit: Well I think it went away I guess, but I got another really loud noise. It's from the IM area, kinda sounds like its below it too. Sounds like a loose bolt or something rattling around, its on and off. its a gsr
Modified by DrZoidberg at 7:40 PM 4/26/2007
Old Apr 26, 2007 | 02:46 PM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (DrZoidberg)
Old Apr 26, 2007 | 04:33 PM
boomersz's Avatar
Old Apr 26, 2007 | 04:43 PM
g0tgot's Avatar
IM dunno what that means sorry, if it is coming from the head, might need a valve adjustment, if it is from the distributor, clean the contacts...........
boomersz's Avatar
Default Re: (g0tgot)
sorry, Intake Manifold.
Old Apr 26, 2007 | 04:46 PM
CompanyFlow's Avatar
I have the same problem. Its a ticking sound that sort of sounds like arcing as well. Im pretty sure its an injector.
Old Apr 26, 2007 | 10:01 PM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (CompanyFlow)
bump?
Old Apr 26, 2007 | 10:13 PM
VTEC_PRODUCTION's Avatar
valvetrain...nothing major...
Old Apr 26, 2007 | 10:16 PM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (Acura_Integra_Type_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_Integra_Type_R &raquo;</TD></TR><TR><TD CLASS="quote">valvetrain...nothing major...</TD></TR></TABLE>
Old Apr 26, 2007 | 10:26 PM
deadline's Avatar
valve adjustment...
Old Apr 26, 2007 | 10:29 PM
boomersz's Avatar
Default Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">valve adjustment...</TD></TR></TABLE>
will it hurt anything to drive around............................................ .................................................. .................................................. .................................................. .................................................. .................................................. ....
Old Apr 27, 2007 | 07:31 AM
boomersz's Avatar
i can hear it at idle and while driving. it's on/off noise...
Old Apr 27, 2007 | 09:22 AM
BryaninVegas's Avatar
Mine did the same thing with the ticking, if you hit the gas pedal it does it more. I took it to the Acura dealership here in town. They did a valve adjustment ($250 later) I was told that it will always tick since the valve train does not have hydraulic lifters so you will hear it. Mine still ticks, just not as bad as before.
Make sure your oil is always at level, I notice it's not as bad with full oil in the motor. Especially when it's new oil.
Old Apr 27, 2007 | 09:42 AM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (BryaninVegas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryaninVegas &raquo;</TD></TR><TR><TD CLASS="quote">Mine did the same thing with the ticking, if you hit the gas pedal it does it more. I took it to the Acura dealership here in town. They did a valve adjustment ($250 later) I was told that it will always tick since the valve train does not have hydraulic lifters so you will hear it. Mine still ticks, just not as bad as before.
Make sure your oil is always at level, I notice it's not as bad with full oil in the motor. Especially when it's new oil.</TD></TR></TABLE>
When give it gas it doesnt really get louder...i swear its a loose bolt but i cant find anything. i will randomly hear it when im driving or idle.
Old Apr 27, 2007 | 01:30 PM
boomersz's Avatar
anyone else?
Old Apr 27, 2007 | 03:33 PM
boomersz's Avatar
checked under and around, cant find anything
Old Apr 27, 2007 | 06:39 PM
boomersz's Avatar
helllp
Old Apr 28, 2007 | 10:44 AM
boomersz's Avatar
Old Apr 28, 2007 | 11:01 AM
95 integra's Avatar
Possible answers:
Valve adjustment
Worn/Bad LMA
Bad rod bearing
Bad distributor bearing
Sticking injector
Loose bolt
Some other loose metal object
There are a couple bolts that go into the bottom of the intake manifold that might be loose, so get under the car and take a look way up in there. Stick your hand in there, wiggle **** around,etc. Make sure all your brackets are tight. Other then that, nobody here can help. I mean.....people name things and you dont even try them before asking for more help. How many people have said valvetrain/valve adjustment and you just go right on over and post asking for help again. This time, don't post again until you have checked everything on the list above....because chances are pretty good that its something on there.
Old Apr 28, 2007 | 11:04 AM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (95 integra)
what has anyone suggested that i havent tried, besides getting a valve adjustment? it doesnt sound like its coming from the head...and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrZoidberg &raquo;</TD></TR><TR><TD CLASS="quote">checked under and around, cant find anything </TD></TR></TABLE>
Old Apr 28, 2007 | 11:07 AM
DraginTeg93's Avatar
my valves made noise and just got them redone sounds great and runs better
Old Apr 28, 2007 | 11:09 AM
boomersz's Avatar
ill try to get a video or sound clip up today.
Old Apr 28, 2007 | 04:19 PM
94integragsr's Avatar
Banned
Default Re: (DrZoidberg)
the injectors are noisy
FijiBlueFG2
Honda Civic (2006 - 2015)
17
Sep 8, 2010 03:45 PM
NSfit
Honda Fit
Oct 26, 2007 04:40 AM
boomersz
23
Apr 28, 2007 10:43 AM
es_squared
Mar 15, 2007 06:48 PM
jbhondaeg
15
May 9, 2005 06:16 PM
