Pls HELP...problems with my car!
Old May 29, 2002 | 01:58 PM
lePetitePrince's Avatar
Default Pls HELP...problems with my car!
I posted earlier about my engine vibrates like crazy after a hard downshift from 3rd to 2nd. My mechanic check all the engine mount, they are all good, everything else, is still good, they cannot find the problem. They said it might be the LSD or problem in the tranny.. now do you guys think that is a possibilites???
because it costs alot of $$ to open up the tranny.....I will try to get Acura to check out my problem.....anyone know what type of problem it could be???????
Old May 29, 2002 | 02:00 PM
t's Avatar
t
Default Re: Pls HELP...problems with my car! (lePetitePrince)
Did you check the CV joints?
Old May 29, 2002 | 02:02 PM
EagleR's Avatar
Default Re: Pls HELP...problems with my car! (t)
Thats my thought...check in order of expense. Eliminate all the cheap stuff 1st
Default Re: Pls HELP...problems with my car! (EagleR)
yes i did..that's not the problem
Old May 29, 2002 | 02:04 PM
the vibration starts now in 2nd gear around 75km/h...
Old May 29, 2002 | 02:52 PM
help pls help
Old May 29, 2002 | 03:32 PM
t's Avatar
t
How did you check them?
I am almost sure it is the axles CV joints.
But have you and your mechanic jacked up the car on jackstands and drive it looking for the source of the vibration?
Old May 29, 2002 | 09:01 PM
thatz seems what alot of ppl told me to check.....but the machnic siad is fine
how can i tell if the axles CV joints broke or something???
Old May 29, 2002 | 09:03 PM
t's Avatar
t
You got to pull them off the car to check them.
Old May 29, 2002 | 10:11 PM
ok i will do that~ so if the axle/cv joint break??is it easy to tell??? I am sorry but I don't know that much in depth about the mechanical part....
Old May 29, 2002 | 10:30 PM
t's Avatar
t
Usually the rollers get popped out of the socket and freezes up. Problem many drag racers have besides snapping the whole axle.
Tell your mechanic to take a look at it if your not sure, cause sometimes it will look fine
Best way to check for which side if not both is to put the car on jack stands and drive it with someone listening to the axles.
[Modified by t, 11:31 PM 5/29/2002]
sim_charles
Honda Civic (2006 - 2015)
Jul 5, 2010 07:52 AM
civicboy1128
Jun 8, 2008 09:33 AM
Thunder Cat
Feb 24, 2007 07:49 AM
phoshizzle88
Feb 20, 2006 09:19 PM
Moonbus
Dec 28, 2004 11:31 PM
