help... wierd noise...
ok, i drive a 97 coupe, with a soch ZC motor... when in first, as i go up in the RPMs, u can hear a clear sound in tone.... almost as if its vtec, yet i sont have vtec... and deff no power difference...a friend says he thinks i just have a reallllllllly bad exhaust leak, but im not sure.... motor wise, everythings fine, tranny seems fine, no grinds, and when still, it sounds like a mild grind... any help?
Modified by ekcoupe88 at 6:30 AM 5/7/2007
Usually your throwout or input shaft bearing you hear when your clutch is engaged or disengaged. It's not likely that you'll hear it when crusing unless your coasting through a parking lot at 3mph in gear.
Matt (SG)
Jun 5, 2008 05:06 PM
