Need Help With Harness/Wiring for B-series Swap Into CRX
Old Apr 26, 2007 | 07:54 AM
CW-ITR's Avatar
Default Need Help With Harness/Wiring for B-series Swap Into CRX
Alright, I have everything else together and ready to do my swap except the harness/wiring thing. I need to know what harness to use with my set up below:
Car: '91 CRX DX with stock main harness.
ECU: Chipped P28.
Swap: OBD1 converted JDM B18C.
Accesories in hand: OBD0-OBD1 conversion harness, '93 Civic EX engine harness.
So, what do I do to make it work from the chipped P28 ECU to the original main CRX harness to the JDM B18C?
Thanks for your help
Old Apr 26, 2007 | 08:52 PM
CW-ITR's Avatar
Default Re: Need Help With Harness/Wiring for B-series Swap Into CRX (CW-ITR)
I just got back from the junkyard with a jungle of wiring harness in my hand. Since my CRX was an auto converted to manual, and based on the search info that I got on H-T, I decided to pull out the existing main auto harness and swap in the main harness from a manual EF Civic which I just pulled at the junkyard. After that, I'll do the DPFI to MPFI conversion myself.
Two questions:
1. once I conveted it to MPFI, I should be able to hook everything together starting from the MPFI harness into-----> the new main harness, from the new main harness into-----> the OBD0-OBD1 coversion harness, and from the OBD0-OBD1 conversion harness into-----> the chipped P28 ECU right?
2. Since the original CRX gauge cluter won't accomodate the JDM TypeR engine, how do I swap in a B-series gauge cluter such as a typeR one?
Old Apr 26, 2007 | 11:04 PM
Rywire's Avatar
run a cable speed sensor and use stock cluster
Old Apr 27, 2007 | 04:18 AM
CW-ITR's Avatar
Default Re: Need Help With Harness/Wiring for B-series Swap Into CRX (droppedcrxsi)
Thanks Ryan, can you clarify more on the "speed sensor"? Which car do I get it from and where is it located inside the CRX?
Old Apr 27, 2007 | 05:19 AM
mahatma's Avatar
the speed sensor is in the transmission, right where the speedo cable goes in. only a couple bolts hold it down...
did you get the wiring Q's answered already?
you can source o2 sensor & distributor plugs from your '93 harness....
Old Apr 27, 2007 | 08:20 AM
CW-ITR's Avatar
Default Re: Need Help With Harness/Wiring for B-series Swap Into CRX (mahatma)
[QUOTE=mahatma]the speed sensor is in the transmission, right where the speedo cable goes in. only a couple bolts hold it down...<-----So, you are saying I need to swap out the B-series hydro speed sensor for the original D-series sensor from the CRX tranny?
did you get the wiring Q's answered already?<-----No, I want to know if this is the right parts and order: MPFI harness into-----> the new main harness, from the new main harness into-----> the OBD0-OBD1 coversion harness, and from the OBD0-OBD1 conversion harness into-----> the chipped P28 ECU.
you can source o2 sensor & distributor plugs from your '93 harness....[/QUOTE]<-----So, you are saying I can use the o2 sensor and the distributor plugs from my '93 Civic EX harness in my MPFI harness?
Thanks alot "mahatma"
Old Apr 27, 2007 | 08:27 AM
Rywire's Avatar
use d series sensor in tranny, use dx engine harness, and add obd1 parts, do dpfi to mpfi, or have me do it, and use ecu jumper
Old Apr 27, 2007 | 12:49 PM
mahatma's Avatar
it might cause you more problems to swap engine harnesses. i've been told (by droppedcrxsi among others) that harnesses are year, model, & even trim specific. changing that could doom your from the start!
i don't think there are any appreciable differences between engine harnesses from manual or automatic vehicles.
just use a good dpfi--->mpfi guide, double check your *** off, and only do one step at a time unless you're damn sure that cutting corners is the way to go. one example of 'cutting corners' is injector wiring. dpfi--->mpfi normally calls for you to wire in a resistor box. but obd1 injectors don't need it.....so you'd be doing that step unnecessarily.
good luck
Old Apr 27, 2007 | 01:05 PM
CW-ITR's Avatar
Thanks "mahtma" and "droppedcrxsi", you two are great I'll do the DPFI-MPFI first and try that out before I go with swapping out the entire main harness.
jdmsuckah
Jun 23, 2010 06:37 AM
1BADEF
Sep 12, 2008 01:49 AM
JDMInspired
Honda Civic (2001 - 2005)
Jul 2, 2008 01:19 PM
ikaika3269
10
Feb 26, 2008 06:25 PM
CW-ITR
Apr 26, 2007 08:50 PM
