Is changing automatic transmission fluid the same as 5 speed transmission fluid??
ok i will be chaning my girlfriends tranny fluid. will of course she gots an 1998 automatic so is it the exact same procedure on the automatic and 5 speed? if so then im pretty sure i can do it no problem. also is it the same amount of fluid that will be needed? give me all the info i will need cuz i will be doing this in the weekend thanks
It is not the same. Check the Helm manual for the procedure. Search google for "hondahookup manuals".
I think its actually easier to change automatic tranny oils because you can fill it through the dip stick hole. Manual you need like a pump or something, theres more to it for manual and there is a DIY here or on Team-Integra.net
uberEFtuner
Jan 31, 2011 06:34 AM
mynameizstitch
Apr 26, 2007 12:26 PM
mystikz2002
Acura TL, RL & ZDX
12
Jan 20, 2005 09:22 AM
DamonBoost
Oct 27, 2001 02:28 AM
