ZFR NGK Plug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 »</TD></TR><TR><TD CLASS="quote">What would be the worse outcome of using a number 6 plug on a 12.5CR engine?</TD></TR></TABLE>
You will not be able to run as much ignition timing.
You will be more prone to detonation under load.
You will not make as much power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 »</TD></TR><TR><TD CLASS="quote">Guess the hunt begins for my 7 plugs. What would be the Denso equivalents to NGK BKR7E-11 plugs?</TD></TR></TABLE>
Whats wrong with NGK plugs?
where is here? I wouldnt mind sending a couple boxes to you. the are $15 a box my cost 1 box has 10 plugs in it.
and yes. i use bkr7e11 in my motors. 1283 is the NGK number. everytime i go to my local parts store, its like french fries, i get a box with every order. too cheap not to change. and every race weekend is a box of plugs
TeamTooQuick
Aug 9, 2003 07:23 PM
