Passenger side power lock
Old Apr 26, 2007 | 01:28 AM
IBriaIN's Avatar
Default Passenger side power lock
The
passenger side power lock does not work. The door locks fine, but I
guess
the wiring for the power lock switch for the passenger side is bad.
any ideas to fix this problem?
thanks,
brian
Old Apr 26, 2007 | 03:41 AM
godnf8's Avatar
Default Re: Passenger side power lock (IBriaIN)
Just the switch doesn't work from the passenger side?
Dot the passenger door lock when you use the drive side switch?
You can take the door panel off and take a look at the contacts, I've seen the contact in the plug harness get corrosion on them and cause issues.
new5gen
Honda CR-V & Element
Mar 22, 2017 06:50 AM
stopspazinout
Aug 15, 2013 12:40 PM
j4s0n1337
Apr 4, 2012 07:28 AM
wakaranai
Feb 13, 2009 01:50 AM
bonta-kun
Oct 10, 2006 03:14 PM
