JDM 4-1 ITR Header+what exhaust
Old Apr 26, 2007 | 12:39 AM
Oggy_EG4's Avatar
Default JDM 4-1 ITR Header+what exhaust
Hello,
EG4 Civic with swap engine is B16A2 with port&polish head. I got the uper header. What exhaust will be the best? 2" or 2,5"
Old Apr 26, 2007 | 01:41 AM
BlueIntegraBoy's Avatar
Default Re: JDM 4-1 ITR Header+what exhaust (Oggy_EG4)
I would continue 2.5" all the way back from the collector.
Old Apr 26, 2007 | 09:39 AM
Oggy_EG4's Avatar
Ok, but is it maybe too "wide" for stock engine?
Old Apr 26, 2007 | 10:45 AM
dao_yaj's Avatar
i'd go with a 2.5"
Old Apr 26, 2007 | 10:58 AM
B16b-EJ8's Avatar
2.5" works fine
Old Apr 26, 2007 | 11:00 AM
MR.johnson's Avatar
Default Re: (B16b-EJ8)
2.5
/thread
Old Apr 26, 2007 | 11:29 AM
Default Re: (Oggy_EG4)
You don't want to bottleneck your exhaust.
Old Apr 26, 2007 | 11:30 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (BlueIntegraBoy)
2.5" ftw.
Old Apr 26, 2007 | 11:54 AM
Oggy_EG4's Avatar
2 BlueIntegraBoy: What that means?
Old Apr 26, 2007 | 01:29 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oggy_EG4 &raquo;</TD></TR><TR><TD CLASS="quote">2 BlueIntegraBoy: What that means?</TD></TR></TABLE>
I can answer this for you...If your header is the 98+ JDM ITR header the collector is 2.5" so if you get a 2" exhaust you will get a bottle neck effect (like an old fashioned coke bottle)
Old Apr 26, 2007 | 02:06 PM
Agent_EM1's Avatar
Old Apr 26, 2007 | 05:12 PM
Ya Digg's Avatar
Default Re: (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">2.5 </TD></TR></TABLE>
X2 it would not be right to put a smaller exhaust then the size of the header collecter which is 2.5 inches on an ITR header
Old Apr 26, 2007 | 05:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
I can answer this for you...If your header is the 98+ JDM ITR header the collector is 2.5" so if you get a 2" exhaust you will get a bottle neck effect (like an old fashioned coke bottle)</TD></TR></TABLE>
Correct.
Here's my 2 minute drawing...
Old Apr 26, 2007 | 09:33 PM
Oggy_EG4's Avatar
Tnx all!!
Then 2.5 it goes
Old Apr 26, 2007 | 09:34 PM
small talk j's Avatar
for 2.5
Old Apr 28, 2007 | 07:30 PM
Ya Digg's Avatar
Default Re: JDM 4-1 ITR Header+what exhaust (small talk j)
2.5" FTW
Old Apr 28, 2007 | 08:45 PM
Harryflores's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
this is good info for nOOb's !
Old May 14, 2007 | 08:57 AM
Oggy_EG4's Avatar
Default Re: (Harryflores)
Stock B16
+JDM ITR exhaust header
+Fujitsubo LegalisR 2.5"
=Buhahahaha
before 161 HP
Now 151 HP
Where is the catch?
Old May 14, 2007 | 09:00 AM
bobobob's Avatar
everything really the same? same dyno?
Old May 14, 2007 | 09:10 AM
Oggy_EG4's Avatar
Same dyno
Temperature was 10 degrease higher. I don't believe that causes the runaway of horses
Old May 14, 2007 | 09:30 AM
doood's Avatar
been there done that
you cant compare numbers from different days with different weather conditions even if it's on the same dyno
Old May 14, 2007 | 09:42 AM
Oggy_EG4's Avatar
Default Re: (doood)
OK, but in the driving I feel the lack of power. 10 HP is too much to lose including the different wheather conditions.
DeL SLo
Sep 25, 2004 06:31 PM
Train
Mar 10, 2004 09:57 PM
NIKE SB'd
21
Nov 21, 2003 08:32 AM
red civic standard
Mar 20, 2002 12:17 AM
