k20 mounts with crx hood?
Old Apr 25, 2007 | 08:38 PM
BEAVERTOOTH's Avatar
Default k20 mounts with crx hood?
I was wounder who makes mounts for a k20 in a crx without the need for cutting the hood open? Can I see some pics too if you have them? thanks
Old Apr 25, 2007 | 09:20 PM
locash's Avatar
Default Re: k20 mounts with crx hood? (BEAVERTOOTH)
Nobody does.
If you want to keep the stock hood, the oil pan will be WAY too low. If that is your plan, time to one off a mount kit..
Old Apr 26, 2007 | 06:50 AM
Default Re: k20 mounts with crx hood? (locash)
What about using the jdm hood?
Old Apr 26, 2007 | 02:22 PM
crx2nr822's Avatar
If you use the Hasport mounts with a SIR style hood(carbon fiber or metal), it will clear, but you will have to trim some of the webbing underneath. If you get the FiberImages SIR style carbon fiber hood, it will fit with no modifications because the FI doesnt have webbing underneath which leaves the necessary space you need to make it fit.
And if you want a k24 underneath the hood, your pretty screwed
Old Apr 26, 2007 | 06:21 PM
Default Re: k20 mounts with crx hood? (crx2nr822)
LOL Thanks I guess scrap the k24 and does anybody have any pics?
Old Apr 26, 2007 | 07:23 PM
crx2nr822's Avatar
What do you want pics of? I can post some links that show the hood closed and everything.....lemme know
Old Apr 26, 2007 | 07:49 PM
Thanks that would be great.
Old Apr 26, 2007 | 07:52 PM
crx2nr822's Avatar
I'll post the link right now.....
EDIT:Damn bro, I forgot to mention that you have to use the 3 pulley setup and get rid of the idler pulley to make it work.
Old Apr 26, 2007 | 07:55 PM
crx2nr822's Avatar
Here is the link:
http://www.k20a.org/forum/showthread.php?t=1040
If you scroll down you'll see a pic of the red crx with a 3 pulley setup and the FiberImages hood closing fine. And if you go down even more, you'll see the 3 pulley setup I was talking about.
Old Apr 26, 2007 | 11:00 PM
Thanks man thats what I needed to see, and your cars looking good.
Old Apr 27, 2007 | 02:17 AM
crx2nr822's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEAVERTOOTH &raquo;</TD></TR><TR><TD CLASS="quote"> Thanks man thats what I needed to see, and your cars looking good. </TD></TR></TABLE>
what car? I just have an EF beater sedan right now
Old Apr 27, 2007 | 06:46 AM
SpeedSceneScott's Avatar
I have a one piece front end on my CRX with a K24 and had to cut a hole for clearance. I bought a low cowl induction scoop and am going to glass it on to cover the hole. I have it sitting on the hood now and it looks great. Check out the photos at http://www.speedsceneracing.com on the racecar project page and you can see how it looks.
Dont scrap the project, just make it work!
Old Apr 27, 2007 | 10:51 AM
Default Re: k20 mounts with crx hood? (SpeedSceneScott)
Sounds good
88'CRXsi
Mar 2, 2008 08:21 AM
JsEFx
15
Sep 24, 2004 09:32 AM
rhetorical
18
Sep 14, 2004 09:32 PM
apexinghonda
May 24, 2004 01:28 PM
Outkast_CL9
15
Sep 20, 2003 11:13 AM
