quick question........
Old Apr 25, 2007 | 06:09 PM
em1mike's Avatar
Default quick question........
http://www.hmotorsonline.com/s...10002
will these ctr pistons fit directly into my block, and do they come w/all four..
thanks
also i know i will need new rings
thanks in advance
Old Apr 25, 2007 | 06:16 PM
SkertySkerty's Avatar
well i think it would help for you to tell us what BLOCK YOU HAVE ... let us know and ill tell you if they'll work dawgy
Old Apr 25, 2007 | 06:19 PM
em1mike's Avatar
Default Re: quick question........ (em1mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1mike &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hmotorsonline.com/s...10002
thanks
thanks in advance</TD></TR></TABLE>
Old Apr 25, 2007 | 06:21 PM
pdiggitydogg's Avatar
Im going to ASSUME, that since your SN is em1, that means you have a b16a....
If thats true, the answer is yes (also assuming no work has been done on it, order the std size)
Recommended that you hone the cylinders before installing them, however.
It clearly says "piston SET" meaning 4
Be sure to order new rings while youre at it
you dont know what youre doing....do you?
Old Apr 25, 2007 | 06:32 PM
em1mike's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Im going to ASSUME, that since your SN is em1, that means you have a b16a....
you dont know what youre doing....do you?</TD></TR></TABLE>
GOT A BALLPARK IDEA OF HOW TO do things i dont need done from shop and what i do need
yes b16a
im gon get
HOT TANK THE BLOCK FOR NEW FACTORY LOOK
crank-balanced&micropolished
cylinders honed
ctr pistons
oem rings
shot peen rods
and arp head bolts..
anything im missing...?
would this be a waste on TORQUELESS BLOCK??
should i sell and get gsr block w/type r internals, which route may seem best
factoring money will be no issue
Old Apr 25, 2007 | 06:59 PM
well a b16 block and a gsr block a basically one in the same you can always sleeve the b16 bore it out the good thing about the b16 is the short strock which means higher rev baby yeah im sorry i love N/A have fun with your build do it big
connor53
Sep 11, 2008 06:26 PM
Chief Wenceslaw
Apr 14, 2006 07:07 PM
kidd_drastic
Nov 11, 2005 12:39 PM
SLEPTONEG6
Dec 22, 2003 12:10 PM
vsi
Apr 30, 2003 06:35 PM
