Compression test range on a LS in my EF hatch?
Old Apr 25, 2007 | 05:52 PM
Creator's Avatar
Default Compression test range on a LS in my EF hatch?
It has been a little while since I searched for a LS compression test to compair to, which I found none, so this was the first test
cylinder 1-138, 2-135, 3-135, 4-137
After re-searching I realized I forgot to open the TB and the second test
cylinder 1-167, 2-163, 3-165, 4-170
My understanding is that as long as the numbers are all within 10psi of each other then your in good shape. <U>What I could not find is what the high and lows across the board should be for an LS</U>. Any takers?
Old Apr 25, 2007 | 07:19 PM
jakscivic's Avatar
Your compression looks fine. I believe that you may be more on the high end of the ls compression.
armintheman
Oct 4, 2010 09:57 PM
Creator
Apr 26, 2007 09:55 AM
B18PoweredCivic
Nov 12, 2004 03:49 PM
spoonfed95
May 20, 2004 04:39 PM
Jamison
Feb 11, 2002 08:51 PM
