FS:ERL 84mm GSR block,Built Heads,twin disc,turbo,manifold,exhaust,tial,apexi,greddy,tons more insid
Old Apr 25, 2007 | 05:03 PM
jsnm's Avatar
Default FS:ERL 84mm GSR block,Built Heads,twin disc,turbo,manifold,exhaust,tial,apexi,greddy,tons more insid
Everything Updated
Selling everything due to a streetbike accident:
UPDATE:
I moved everything still for sale towards the top for easier viewing.
Precision GT35R Turbo-charger,brand new,4-bolt Exhaust side-$1350 shipped:
No pics yet
-Transmissions(no shipping on these,i could meet halfway or something if close by):
-92 LS Automatic Transmission-$250
-95 GSR Hydro Transmission,smooth shifting,no grinds,perfect-$600
-94 LS Hydro Transmission,grinds in 5th-$450
-Eagle LS rods-just 3,not 4,with ARP rod bolts,and Probe 9:1 forged pistons all 3 in excellent shape,nothing wrong with them or the rings-$105 shipped for all 3
-Blocks(no shipping on these either)-
-Bare B18A1 Block w/crank and main caps-$200
-B18B1 Shortblock(complete rotating assembly)-SOLD-
-Complete B18A1 longblock w/out trans,wiring harness,sensors,everything inluded except trans-$450
-B16A JDM shortblock(complete rotating assembly)-$250
-Hondata GSR intake manifold gasket used-$40 shipped
-ARP B16 head studs-$90 shipped
-3'' Love-FAb and FSMoto Custom downpipe with 5 bolt flange,1 upper o2 bung,1 lower o2 bung,stainless flexpipe and 3'' 3 bolt flange to bolt to exhaust-$255 shipped
-fox-stock.com oil pressure 4-port firewall mounted oil block,w/line for block and 1 ,line for oil feed for turbo-$105 shipped
-auto-meter water temp gauge-ultra-lite2-$55 shipped-
-si full-race traction bars-$355 shipped-
-94-95 integra front turn lights-oem-$22 shipped-
-b16,b17 and b18c5 aebs intake manifold(with all sensors,and throttle body)-$125 shipped-
-brand new! in box obd1 gsr distributor with new rotor too-$355 shipped-
94-95 integra tape player-$30 shipped-
-OEM Civic Type R N1 crank pulley,still in honda packaging,with a brand new right sized alternator belt-$85 shipped
-New tube of M3 Windo-Weld-for filling in motor mounts to make solid-$25 shipped
SPARK PLugS:
-I have 4 brand new NGK BKR7E Spark Plugs-$6.50 pce. shipped
-94-95 green integra gsr oem side mirrors(power) need paint-$45 shipped
OIL PanS:
-OEM LS stock oil pan with -10 male bung welded on for turbo return line-$95 shipped
-OEM GSR stock oil pan with -10 male bung welded,and a cap to cover it-$95 shipped
-94-99 GSR Stainless resonated Test Pipe-$75
-94-95 GSR Gutted OEM Cat-$35
-99-00 Civic Si Stock (Filled) Motor Mounts(no torque mounts):
Rear mount(solid 3m filled)
Pass side trans mount(solid 3m filled) with trans bracket
Drivers side upper mount with bracket-$150 shipped for all of it
-94-99 GSR AEM V2 cold-air intake,complete kit,all couplers,piping,filter,clamps,a/c line bracket,etc-$150 shipped
-Stock Toyota MR-2 Intercooler,perfect shape,no bent fins,all black,comes with couplers and clamps.-$65 shipped
If your interested,call me or pm me on here.
pm works best for me.
Contact info:
location-Delaware
AIM-tenchijin8
e-mail:dragon568@hotmail.com
paypal address:dragon568@hotmail.com
Shipping info:
I am only shipping to the lower 48 states,NO Alaska,No Hawaii,No Canada,sorry.
Anything ordered will be promptly sent out within a couple days,either by UPS or USPS priority.
<U>I accept paypal mostly for the quickest shipping and ease of transaction,but if your using paypal,please ADD the 3% for the paypal fees,paypal is killin me with that.</U>
I also can accept money orders.
SOLD Items:
The Block is a 95 GSR block,sent out to ERL,they sleeved it,cleaned it,micro-polished the crank,and hooked me up with a 5-bolt main girdle.The Sleeves are 84mm,with Pauter X-Beam Rods,CP Coated Pistons,coated new bearings,and ARP bolts,etc:
ERL Block-SOLD-SOLD-SOLD-SOLD:
94 GSR Race-Ready Head-SOLD-
98 GSR Race-Ready Head-SOLD-
Cometic 84mm Headgasket-SOLD-
Edelbrock VictorX GSR Intake Manifold-SOLD-
Fluidamper Street(new Version with removable power steering pulley) Crank pulley-SOLD-
Tial 50mm Blow-off valve-polished-SOLD-
Tial 46mm Wastegate-polished-SOLD-
Love-Fab Equal-length ramhorn turbo manifold-SOLD-
Precision 1000cc peak and hold Fuel injectors-SOLD-
-plx wideband-SOLD
-Cometic Copper Turbo exhaust gasket-SOLD-
-Cometic T3 turbo gasket-SOLD-
-OEM gsr water pump-SOLD-
-Greddy GSR timing belt-SOLD-
-Golden eagle ls/vtec conversion kit minus the headgasket-SOLD-
-8 ARP extended wheel studs-SOLD-
-ARP pressure plate bolt set-SOLD-
-Stainless steel Kteller full 3'' bolt up cat-back exhaust piping kit for 92-00 civic coupe-SOLD-
-Apexi N1 polished 3'' turbo muffler-SOLD-
-92-00 Civic all,polished full aluminum intercooler piping kit-SOLD-
-Pilot HID plug and play heaqdlights kit,high and low beam-SOLD-
-Fast-Turbo.com big fuel kit,-8 full lines,all the fittings,brand new kit-SOLD-
-Aeromotive Fuel pressure regulator-SOLD-
-Aeromotive Inline fuel filter-SOLD-
-AEM blue fuel rail-used-SOLD-
-skunk2 magnetic oil and trans drain plugs-SOLD-
-tuner-toys 3bar map block off with vacuum fitting for a 3bar map sensor-SOLD-
-GM 3bar map sensor with pigtail harness and connector-SOLD-
-Greddy 60mm warning gauge all black boost-SOLD-
-Greddy 60mm warning gauge all black egt-SOLD-
-Greddy black turbo timer-SOLD-
-SVE turbo-timer plug-n-play harness-SOLD-
-Hondata S200 with boost and datalogging option,with hondata obd1 ecu with obd2 socket-SOLD-
-Golden eagle GSR oil squirter block-off plugs-SOLD-
-94-00 teg z3 fenders-SOLD-
-96-00 civic gauge bezel-SOLD-
-oil pressure gauge-ultra-lite2-with stainless pressure line-SOLD-
-gm 3bar map wit harness-SOLD-
-tuner-toys 3bar map adapter-SOLD-
-hondata s200-SOLD
-plug-n-play Pilot hid kit-SOLD-
-intercooler piping-SOLD
-Real Type R seats-both fronts-mint condition-pickup only-SOLD-
-greddy oval catch can-SOLD
-99-00 civic si radio-SOLD
-99-00 civic type-r replica headlights,mint condition-SOLD
-BFG Drag Radials,like brand new,only 2 passes on them,size-205/50-15-SOLD-
-Moroso B-series Aluminum 6qut. oil pan,comes with hardware,and plugs,extra washers,and it comes with a moroso LS oil pickup.If using a Vtec block,the -moroso vtec pickup must be used.-SOLD-
-plx wideband-SOLD:
-fidanaza-SOLD-
-99-00 Civic VIS carbon fiber hood-also flawless-SOLD:
-Omni-Power Full Coil-over suspension kit-SOLD-
-auto-meter boost gauge-phantom-SOLD-
-Competition Clutch Twin-Disc Clutch Kit-SOLD-
-Precision 750HP Front mount bar and plate intercooler-SOLD-
-99-00 Civic Electron Blue Pearl Front Lip-Flawless-SOLD-
-greddy boost controller-SOLD-
-94-00 integra,92-95 civic h-brace-SOLD-
-gsr msd cap and blaster ss coil-$75 shipped-SOLD-
-Walbro 255lph HP in-tank fuel pump,and inline fuel pump both with install kits and mounting hardware(walbro in-tanks are sold)inline(comes with mounting and electrical hook-up hardware too)-SOLD-
Modified by jsnm at 12:59 PM 9/5/2007
Old Apr 26, 2007 | 04:00 AM
m3rd3074's Avatar
Default Re: FS:ERL 84mm GSR block,Built Heads,twin disc,turbo,manifold,exhaust,tial,apexi,greddy,tons more i
bump this
Old Apr 26, 2007 | 03:53 PM
jsnm's Avatar
thanks,ill try to get some more pics tomorrow
Old Apr 26, 2007 | 04:43 PM
Joey Tribianni's Avatar
how much for your injectors, i have a set now but they are on loan while i i was dyno tuning. i live on Vancouver Island, in B.C. Canada. so hopping you are willing to ship
Old Apr 28, 2007 | 04:42 AM
jsnm's Avatar
fixed all the pictures,you got a pm
Old Apr 29, 2007 | 09:17 AM
jsnm's Avatar
to the top,adding more parts
Old Apr 29, 2007 | 04:37 PM
jsnm's Avatar
just added tons more parts,pm if interested or call the cell
Old Apr 30, 2007 | 06:28 AM
quickda6's Avatar
Default Re: (jsnm)
All of Jesse's parts are top shelf, especially that shortblock.
The GT35R he has listed also comes with a 4bolt to vband adapter.
If anyone has any specific questions, feel free to pm or call us(FSM).
Get better soon Jess!
Josh
Old Apr 30, 2007 | 03:16 PM
jsnm's Avatar
thanks alot josh,i already sold a few things already,sucks it had to come to this,especially after everything i got.
guess ill be listing my cars up here soon..
Old Apr 30, 2007 | 04:13 PM
96 GSR-T's Avatar
ill give you a little over 1k for the 35R as that is what they can be bought for on here, how far are you from FSM?
Old May 1, 2007 | 04:37 AM
jsnm's Avatar
up
Old May 1, 2007 | 02:52 PM
jsnm's Avatar
well look,i paid 1550$ for that 35R,also comes with the 4-bolt to v-band adapter,you got a pm
Old May 1, 2007 | 09:06 PM
jsnm's Avatar
ttt
Old May 2, 2007 | 01:30 AM
mikeycivic's Avatar
Default Re: (jsnm)
bump cuz it sucks you got to sell all this stuff
Old May 2, 2007 | 07:09 AM
El_cOuZiN's Avatar
you got pm!!
Old May 2, 2007 | 01:42 PM
jsnm's Avatar
all pms returned
Old May 2, 2007 | 05:22 PM
jsnm's Avatar
just added more stuff and more pictures
Old May 2, 2007 | 10:02 PM
yz125rider21's Avatar
bump...nice parts
Old May 3, 2007 | 06:28 AM
El_cOuZiN's Avatar
pm again!!
Old May 3, 2007 | 06:31 AM
jsnm's Avatar
thanks,all pm's replied
Old May 3, 2007 | 07:33 AM
El_cOuZiN's Avatar
again and again!!
Old May 3, 2007 | 10:48 AM
92eh3si's Avatar
pm sent
Old May 3, 2007 | 12:33 PM
ivt-t's Avatar
im'ed
bump
Old May 3, 2007 | 04:10 PM
jsnm's Avatar
all pm's replied,keep em comin!
a few things sold already...
Old May 3, 2007 | 06:06 PM
jsnm's Avatar
bump
