Sunroof troubleshooting [89 rex si]
Button works, motor spins, sunroof stays stationary. I've messed with it a bit but can't seem to figure out the problem.
Any suggestions?
P.S.
Sorry if there ends up being a lot of different questions from me. I'm new to the scene and just trying to learn as much as I can.
Thanks
Any suggestions?
P.S.
Thanks
u sure the tracks are fucked up? look at the sliding part of the track to see if it is sliding....and if its hooked onto the top panel
Hmm, everything seems hooked up. It's extremely hard to view the tracks etc because it's stuck (closed). When the motor spins it doesn't look like it's even trying to open. How would I go about taking it off to check out the tracks and whatnot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hi. I’m new. »</TD></TR><TR><TD CLASS="quote">Hmm, everything seems hooked up. It's extremely hard to view the tracks etc because it's stuck (closed). When the motor spins it doesn't look like it's even trying to open. How would I go about taking it off to check out the tracks and whatnot?</TD></TR></TABLE>
remove your healiner
well....can u push it by hand up and does it move after that? try the manual crank and see if it rolls back....u gotta somehow get the top panel sliding back either by hand..or however and then look at the tracks
BTW i have changed out my sunroof twice, and just did a friend of mine with a CRX...haha so removing and installing the entire panel, and tracks is so easy for me...
the rear of the sunroof needs to go up and clear the roof(its probably hitting the roof)try lifting the rear of it then try the switch.
i had to drop the whole assembly last week to replace the mounts
if you need help let me know
Thanks =]
I attempted to lift the rear of the sunroof above the roof of the car and it refuses to clear it.. it seems if I push it up any higher I'm gonna snap something. When I push it up by hand and try the button at the same time still nothing happens. The motor just spins.
Your best bet is to take out the headliner and actually observe what's going on with the motor and tracks. I've seen some threads on here where a bolt came loose and screwed everything up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Your best bet is to take out the headliner and actually observe what's going on with the motor and tracks. I've seen some threads on here where a bolt came loose and screwed everything up.</TD></TR></TABLE>
Yeah, all of that is already removed
Nothing looks too out of place, although I don't have much to compare it to.
The tracks etc don't move at all when the motor is spinning. Nothing moves or attempts to move.
Hellzcivic
Honda Civic (2006 - 2015)
Jan 20, 2007 06:29 PM
Rex89
Oct 11, 2006 05:45 PM
ImportechPerformance
11
Dec 13, 2004 11:39 AM
projektCRX
15
May 2, 2004 07:07 PM
