Just did a swap, cluth pedal palls to floor, why?
Old Apr 25, 2007 | 04:15 PM
.Thomas's Avatar
Default Just did a swap, cluth pedal palls to floor, why?
i dont see any leaks or anything, and i added fluid, whats the problem?>
Old Apr 25, 2007 | 04:30 PM
hondakevin21's Avatar
Default Re: Just did a swap, cluth pedal palls to floor, why? (TanCar)
Did you bleed the system?
Old Apr 25, 2007 | 04:31 PM
.Thomas's Avatar
Default Re: Just did a swap, cluth pedal palls to floor, why? (hondakevin21)
probably not, is there a how to?
94eh2's Avatar
try bleeding the system and make sure the slave is on there correctly
Old Apr 25, 2007 | 04:35 PM
pdiggitydogg's Avatar
bleeding the clutch system is the same as brakes:
open the bleeder screw on the slave, press pedal + collect fluid via hose
close bleeder, let go of pedal/pull it up
repeat
Or, if you have one, a vacuum pump works 1000x faster - just create some (-) pressure on the bleeder, open it up and let it do the work for you.
Either way, be sure the MC doesnt empty out
(same as with brakes...duh)
sing
May 20, 2013 05:28 AM
autoxthis
Honda Civic (2001 - 2005)
Aug 22, 2008 10:08 AM
autoxthis
Aug 21, 2008 08:23 PM
BDRphaSe2
Aug 13, 2006 07:04 PM
carblegal
Mar 24, 2003 08:24 PM
