FFFFF! UCA PROBLEM!?
I purchased a set of Omni Power upper camber arms for my 97 dc2 gsr from Intec Racing (who were cool as hell for driving them out to me! Thanks Mike!!). Upon installation they for some reason did not clear the insides of the fender wells! They seem to be too long.. the part number on the box has been verified with Omni that they "should" be the right part. Baring that the wrong arms were in the box, can anyone give me a suggestion as to why they dont fit right. They apper to be about an inch maybe longer than the stock arms. Has anyone else faced this problem?
Thanks-
Thanks-
that sounds kinda odd....you sure dont have the left and right sides mixed up?
has the front end of your car ever been in an accident?
yeah its really strange, as you can see from the pic's the sides match (R- shown) and the fender liner has been removed..just wont tuck into the fender like it should..and its longer... any help appreciated, as I need to get this back on the road..sucks not having a car!
car is up on blocks now..I decided to put the stock arms back on and a friend came over to "help" me. So said friend striped out the thresds on the ball joint on the drivers side stock UCA..not sure how he managed to do it, but he did. good times! ..wow, now I really need to get this figured out-
I might have your solution. If you look at your first pic, you seem to have adjustable anchor bolts. It is probably these anchor bolts that are pushing the arm out into the fender. With the new arms, you want the adjustment at the ball joint.
So, loosen the lower nut on the adjustable anchor bolts and adjust the arm as far as it will go back towards the car. Then use the adj ball joint on the arms to dail in your camber setting. Or am I trippin?
yeah- right on, went back out into the garage last night to take one last look and then it dawned on me, the anchor bolts are camber adjustable -no DUH right!? I tried adjusting them as much as I could , but still didnt clear. I have been searching high and low for stock ones and no one can get them for some reason let alone sell me some! The dealer (along with a few other shops) told me they only sell them with new control arms..which I dont need (like im the only one who has ever asked for that part!?!). Off to the salvage yard in the Am-
slowly slipping away
Suspension & Brakes
Apr 26, 2007 07:02 PM
slow91crxdx
26
Mar 14, 2007 11:48 AM
slow91crxdx
Suspension & Brakes
Mar 2, 2007 05:31 PM
Drew96EJ
Dec 30, 2003 07:46 PM
