93 h22 lude ABS light??
my ABS light will come on after about 5 min of drving changed sensors an put brake fulid in an for the ABS as well i dont get it any ideas?
I have the same problem, but I haven't changed the sensors. I don't want to H.J. the thread, but could it be possible to clean the sensors somehow without replacing them to not throw the abs light?
Thanks....
Thanks....
pull the abs code by jumpering out the service connector behind the cd player, then turn the key to the on position and read the coad. My guess is that its a "1" being "ABS pump motor overrun"
mine has the same problem and I believe the only way to fix it is to bleed the abs very carefully and get the motor running again. The bleed screw is very deep down on the motor so Im not to sure on how to get an open end wrench on it .
I have the same problem on my '92 H22a swap...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">YOU KNOW YOU OWN A 4th GEN WHEN.......... rofl</TD></TR></TABLE>
^ exactly!
^ exactly!
i was going to add, my abs light just starting going on after 10 seconds of driving. the rear calipar sized and after it was fixed the light has not shut off
Yea I had the same problem, to fix it, just how it was posted earlier, you guyz need to bleed the ABS system, check your 93 handbook to know how to bleed the system the correct way, after you bleed the system, take out the clock fuse to reset the system. After that refill the reservoirs and turn on the car, and then turn it off after a few seconds, and then turn the car on and leave it on for a while.
I hope this works for you guys.
Also check the ABS fuses
no.23 - ECU
no.13 - meter
no.9 - R/C mirror
as well as check the case ground on the abs control unit for corrosion
The abs system has main and sub codes, make sure you use the conecter on the lower drivers side of the center console
no.23 - ECU
no.13 - meter
no.9 - R/C mirror
speed sensors are notorious for failing and they automatically cause abs to trip. if one sensor fails abs will cut out. speed sensors a pita because it could be 1 of 4 or maybe even all of them.
ramz7887
Mar 22, 2007 07:51 PM
