Idle surge
Old Apr 25, 2007 | 12:45 PM
Boostedb20EH2's Avatar
Default Idle surge
I still have an idle surge on my b20. It surges from about 2k to 1k. I have checked all obvious signs. (fitv is tight, just cleaned iacv,did a valve adjustment) I dont know where to look now.
bokals's Avatar
Default Re: Idle surge (Boostedb20EH2)
clean your fitv
Old Apr 25, 2007 | 12:48 PM
Default Re: Idle surge (bokals)
What do you mean by clean it. I have had this problem before and all it took was a quick screw driver to the inner wax of the fitv. But this time when i went to do it, it was set in there tight.
Old Apr 25, 2007 | 01:03 PM
bokals's Avatar
You take the fitv off, open it, spray it with throttlebody cleaner, or brake cleaner, then take it apart, clean it, put it back together...
it fixed my problem and mine was worse then yours, 2500 idle/ surge'd from 1800-2500 constantly..
here are some threads on how to do it
https://honda-tech.com/zerothread?id=1564019
https://honda-tech.com/zerothread?id=699787
Old Apr 25, 2007 | 05:31 PM
Thats how mine used to be, but luckily its only 2k but its still annoying. Alright. Ill try that in a little bit.
Old Apr 25, 2007 | 06:35 PM
Ok...didnt fix it....
Old Apr 25, 2007 | 06:52 PM
EE_Chris's Avatar
Sounds a little like a vac leak.
ls19integra95's Avatar
if it keeps surging up and down and you cleaned the fitv then your tsp sensor might be bad, mine did the same and i replaced it and stopped surging...
Alright heres a quick link to it.. dont mind the stupid indiglos... It only does this when it gets warm..
http://smg.photobucket.com/alb...5.flv
Old Apr 25, 2007 | 07:12 PM
Do you really think a tps or vaccum leak would cause a surge that quick?
Old Apr 25, 2007 | 07:15 PM
thats exactly what mine did and i was told to replace my tps sensor and i did and the idling problem stopped, only problem was the sensor is rivited onto the throttle body and the dealer told me i could only get the sensor if i bought the whole throttle body, so i drilled one off a civic at a junk yard and put it onto mine...
Old Apr 25, 2007 | 07:18 PM
Default Re: Idle surge (ls19integra95)
Dont you think id be throwing a cel for that though? Thats quite an expensive fix..
Old Apr 25, 2007 | 07:58 PM
Any input?
Old Apr 25, 2007 | 08:29 PM
now that i think about it, yah, mine did throw a cel and when i got it checked was how i figured out what was wrong...
Old Apr 25, 2007 | 09:48 PM
x42_BUDDHA_42x's Avatar
Yo my B16 did that same thing and I found a vacuum leak, I fixed the leak and that fixed the surge problem. I think you should check for a leak
Old Apr 26, 2007 | 06:38 AM
Default Re: (x42_BUDDHA_42x)
I'll look for leaks today. When i unplug the wires on my iacv it idles normal..if that helps.
Old Apr 26, 2007 | 07:05 AM
Default Re: (Boostedb20EH2)
Come on i know someone knows the answer. Spread the knowledge
Old Apr 26, 2007 | 07:47 AM
Forty04's Avatar
Could be a number of things. Maybe air bubbles in the coolant system? Bleed the system and see what happens.
Bad tps (if you have a multimeter you can test this quite easily) and if it IS a bad TPS, you can just put a different one on. The screws holding it in are "bare" on top, so you'll have to cut a groove into them (I used a hacksaw, worked like a charm) and they will twist out.
Definitely could be a vacuum leak, those are always fun to try and find
I had this same problem, but mine was due to running the stupid 99-00 y8 IM on a z6, had to seal off some air ports, this probably isn't your situation though..
Good luck!
Old Apr 26, 2007 | 01:06 PM
This is amazing...ive done everything suggested and still nothing
Old Apr 26, 2007 | 02:12 PM
Up for some help..
Old Apr 26, 2007 | 02:17 PM
ITR.#1446's Avatar
i had this problem once read that the fitv controls cold idle and the iac controls it when warm, i thought i had a bad iac because my car would surge once warm also after i did my swap but i actually had the ait sensor and iac plugs switched. not sure if this may be your problem but some suggestions for you
Old Apr 26, 2007 | 02:24 PM
Default Re: (ITR.#1446)
Thanks for the help. It pretty much only does it when its warm..but it idles high cold. I dont think anythings switch because this came out of no where.
Old Apr 26, 2007 | 02:32 PM
Sloshy's Avatar
look and listen very closely for a vacuum leak, broken vacuum hoses, unplug vacuum ports and so on..
Old Apr 26, 2007 | 02:34 PM
T-CHUK's Avatar
eh i got the same problem with my civic..i got a GSR in it and when i start it it revs to about 2500 and slowly goes down to about 1800 but then up agaian and this keeps repeating..but than after abotu 10 mins..it idles regular at about 900...
ne one think of anyhting?
Old Apr 26, 2007 | 05:56 PM
EE_Chris's Avatar
Default Re: (T-CHUK)
If you unplug the IACV, the idle should drop to ~550rpm...which is not a 'normal' idle speed. So if it's dropping to 750ish rpm when the IACV is unplugged, you either have a vacuum leak or the base idle is set to high.
