Sqeaky nose!?!
Old Apr 25, 2007 | 09:56 AM
vi3tromanc3r's Avatar
Default Sqeeky noise!?!
The front of my car seems to sqeek when i drive. I have front camber kits, good shocks, and just changed the upper control arm. Do i just need to lube the camber kit or is it something else. its a 95 civic hatch. Its on both sides of the car and is annoying when i drive.
Old Apr 25, 2007 | 11:37 AM
Default Re: Sqeeky noise!?! (vi3tromanc3r)
bump anyone help?
Old Apr 25, 2007 | 11:47 AM
97Ej6mike's Avatar
If its a constant squeal it could be wheel bearings, or brake rotors
Old Apr 25, 2007 | 11:48 AM
Like Butter's Avatar
might need to re-grease your bushings
Old Apr 25, 2007 | 11:52 AM
deevin9's Avatar
Default Re: Sqeeky noise!?! (Like Butter)
my car had this super annoying squeek, and i couldn't figure out where it was coming from, i thought it was teh shocks, then the seat, but after some intense investigation i found it was my seat belt!!!, the little thing you clip it into was squeeking, so annoying!
Old Apr 25, 2007 | 12:21 PM
Default Re: Sqeeky noise!?! (deevin9)
yea it might be ima probaly going to use some kind of lubricant on everything that moves in my car such as hinges seat belt. also gonna re grease the camber kit bushing, and change rotors some time this week. anybody recommend some kind of lube or grease that i should buy? something from kragen or auto or stores like that?
Old Apr 25, 2007 | 02:54 PM
try some KY jelly warming sensation
Old Apr 25, 2007 | 03:22 PM
B16b-EJ8's Avatar
I'm in the same situation...not a seatbelt though. It is definately coming from the front of the car either under the hood or in the wheel well
Old Apr 25, 2007 | 03:38 PM
Synbios's Avatar
When the squeak is heard can help a lot with the diagnosis.
Do you hear it when you brake? When you accelerate? Go around a corner?
Old Apr 25, 2007 | 03:54 PM
B16b-EJ8's Avatar
Default Re: (Synbios)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synbios &raquo;</TD></TR><TR><TD CLASS="quote">When the squeak is heard can help a lot with the diagnosis.
Do you hear it when you brake? When you accelerate? Go around a corner?</TD></TR></TABLE>
mine is on initial startup of engine when cold...going over speed bumps, and when you shut the door. I really need to get my girlfriend out there to dhut the door while im under the car listening for the squeek.
Old Apr 25, 2007 | 04:01 PM
mines pretty much when you drive. like drive period.
Old Apr 25, 2007 | 04:16 PM
B16b-EJ8's Avatar
Mine could be as well, but I probably cant hear it over the exhaust
Old Apr 25, 2007 | 04:44 PM
so any grease or lube that anyone recommends using?
Old Apr 25, 2007 | 05:19 PM
heavyhittersclub's Avatar
Default Re: (vi3tromanc3r)
buy a stethiscope to help you locate annoying noises,
Is the Noise comming from Inside the car or Under the Hood Somwhere?
Is the Noise comming from the Front or Back of Vehicle?
Drivers side or Passenger side?
How long has the Noise been there?
How loud of a Noise is it?
At Which speed do you Hear it?
Is the Noise Continious or does it come and go?
Do you only hear it over bumps or while turning?
Old Apr 25, 2007 | 05:26 PM
The Si's Avatar
Default Re: (heavyhittersclub)
could be anything , but maybe your power steering, alternator, or AC belt might of ripped check that. or new/old tires or brakes thats some common squeaky sound
Old Apr 25, 2007 | 05:42 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Like Butter &raquo;</TD></TR><TR><TD CLASS="quote">try some KY jelly warming sensation</TD></TR></TABLE>
HA!
Old Apr 25, 2007 | 05:44 PM
i hear it as long as a drive on a bumpy road. and its been there since i've got the camber kit installed. and its defintely coming from the passenger front. im sure its the camber kit just needs some lubing cause it comes from that area.
Old Apr 26, 2007 | 05:07 AM
97Ej6mike's Avatar
Worn bushings maybe?
Old Apr 26, 2007 | 07:16 AM
Default Re: (97Ej6mike)
when i push down on the car even when its off it makes a sqeeky sound, does that mean my bushings are worn and need to change them?
Old Apr 26, 2007 | 07:25 AM
Synbios's Avatar
If you hear it when you start up the car it could be your serpentine belt. You can get a can of belt conditioner for 6 bucks.
Old Apr 26, 2007 | 07:45 AM
97Ej6mike's Avatar
Suspensions squeaking, may be worn bushings, or dirt on the springs (yes, that can make it an annoying squeak-like noise if there is too much dirt on pressure points of the springs)
Old Apr 26, 2007 | 08:07 AM
cycoclown's Avatar
sounds like dirt. did it rain recently? did u drive in dirt?
Old Apr 26, 2007 | 08:09 AM
cycoclown's Avatar
My car did the same thing. Same Area, Clean it, lub it. and your good to go. and BTW do it to all the others.
Old Apr 26, 2007 | 08:59 AM
deadline's Avatar
i know waht your talking about it just happened to my cousin's car....his mounts were going out(driver side). pushing the motor around it wuz sqeaking..rather annoying...try it out.......
Old Apr 26, 2007 | 09:33 AM
94Hatchd15b7's Avatar
Your lower ball joints may be going bad. And my hatch is doing about the same thing and i just pocked a little hole in the rubber boot and srayed it with greese. and it will stop for about six to eight months
