Sway bar question?
Old Apr 25, 2007 | 07:04 AM
88civsedan's Avatar
Default Sway bar question?
This may sound dumb but, I have an 88 civic sedan and I was want to know if I use a sway bar for a civic hatch/crx. Do I have to find one for the sedan, somehow, or will the one for the hatch/crx work? And how will I mount the sway bar? Will I have to drill holes in the subframe, or can I use the bolts for the lca. Please help me with my problem. Thanks.
Old Apr 25, 2007 | 07:10 AM
HBK's Avatar
HBK
Default Re: Sway bar question? (88civsedan)
In order to use a stock rear sway bar, you have to modify the subframe and use si or da lcas. If you want to avoid all of that, get the suspension techniques rear sway which avoids both problems.
Old Apr 25, 2007 | 07:28 AM
88civsedan's Avatar
Default Re: Sway bar question? (HBK)
I bought lcas already because I put coilovers on my car and they have the holes already for the sway bar. How does the suspension techniques bolt in?
Old Apr 25, 2007 | 07:46 AM
89efDUSTY's Avatar
Bolts up to subframe and the endlinks attach with the middle bolt from the LCA going through the bottom of the shock tower via L brackets on both
zippo1130
15
Jan 15, 2008 07:45 PM
Arbiter
Suspension & Brakes
Nov 29, 2007 12:56 PM
CBURKE
Sep 11, 2007 09:22 AM
racin-type
Apr 23, 2003 04:48 AM
Kilohead36
Apr 14, 2002 04:02 PM
